Mysterious overheating 🤬
Old Oct 31, 2024 | 09:24 AM
sony2000's Avatar
A fix not yet mentioned is to wash the radiator. Spray a degreaser on it, then a gentle spray from inside the engine bay outwards, should do it.
Old Oct 31, 2024 | 11:14 AM
Cee Jay's Avatar
I said that way back in post #3. Nobody paid attention to it.
Old Oct 31, 2024 | 12:53 PM
Sean W's Avatar
I did and I went back and hit the like button just for you CeeJay.
Anyway the OP was out here last on the 25th. Let's hope he comes back and at least let's us know if the fan works.
Old Nov 3, 2024 | 05:58 PM
JohnBing's Avatar
The first suspect should be the thermostat and that it is not opening up completely. Change it and check the housing at the same time. Then test it in a pan of boiling water. Not mentioned is the idea that the water pump is slipping under its belt. So has this ever happened before? If you are caught in traffic and the overheat warning happens, beside pulling off to the side of the road and shutting down the engine, its OK to turn up the heat inside the car and open the windows. That helps a lot. I recommend this more than shutting down the engine. Coolant temperature sensors do malfunction and are inexpensive to change, for the do it yourselfers.
Well I took it to my Jaq mechanic and first had the battery replaced as the one out in two years ago was not 100% I had him check the fan he simulated it and says fan is working , so I pick it up bring it home maybe 10 miles and notice a smell like coolant felt the top of the hood was warm but not hot to touch , opened the hood 2 hrs later felt the top of the shroud that covers top of engine and it was still hot not warm but hot I’m at a loss now maybe just change thermostat I quess
jbmi
Jul 5, 2023 01:12 PM
rgfb62
Aug 31, 2022 01:57 AM
mgoldXK
May 5, 2019 06:45 PM
resident_fng
US Southwest
May 16, 2018 08:10 PM
jimatvs
Mar 29, 2011 10:56 AM
