Need advise about 4.2 crankshaft!
Old May 8, 2019 | 04:15 PM
PaiMai's Avatar
Default Need advise about 4.2 crankshaft!
Hi guys!
Will you tell me is it possible to make grinding work for crankshaft of 4.2 s/c engine? And whether exist are bearings of the repair sizes for 4.2 s/c engine crankshaft?
Thank you!
Old May 8, 2019 | 06:07 PM
Ranchero50's Avatar
What does Google say?
Old May 9, 2019 | 04:13 AM
PaiMai's Avatar
Unhappy
Miscellaneous. Frankly speaking I am afraid. Someone writes that it is normally to grinding a crankshaft. Someone writes that the surface of a crank is tempered at its manufacturing. And after polishing the shaft will inevitably break. I do not know what to do.
Old May 9, 2019 | 05:38 AM
steve_k_xk's Avatar
Pai what is the extent of the damage to this particular engine
Old May 9, 2019 | 08:26 AM
PaiMai's Avatar
Excuse me Steve do you ask about the engine of my car?
Old May 9, 2019 | 10:48 AM
Ranchero50's Avatar
Once heat treatment is done it would still need ground at the factory. Heat treatment is only a few thousandths of an inch thick and is more for wear versus controlling stresses. How much needs turned off to clean it up. I was more concerned about what undersized bearings were available. Physically refurbishing the crank should not be an issue.
Old May 9, 2019 | 04:12 PM
steve_k_xk's Avatar
Why do you need a crank .
Did your engine sustain damage ?
Old May 9, 2019 | 05:08 PM
PaiMai's Avatar
Unhappy
I left from car wash. Suddenly on the display the inscription appeared: "Engine Oil Pressure Low". The engine began to make sounds as the old sewing machine (chok-chok-chok). I switched off ignition at once. On mechanical shop removed a case pallet. The oil receiver and oil pump were clean and dry. There was a metal shaving in a pallet of a case. The soured reducing valve was the reason for everything. As a result oil starvation with all that it implies. I think that the crankshaft is damaged. Now the motor is taken out from the car. Until now the engine did not give signs of malfunction. Level of engine oil always was in perfect. Always changed oil for 5000 km. But the car was used seldom. There are such affairs(((
Old May 10, 2019 | 02:08 AM
steve_k_xk's Avatar
sorry to hear that
With oil starvation your going to need more than simply a crank your entire bottom end will mostly likely be shot and the block will have to be honed , decked to make way for new pistons as they will be scored.
The way I see it is you have two options .
Option 1- source a second hand
engine and simply change it over somewhere in the region of $4-6k
Option 2 - full rebuild , very expensive however if you do go down this path whilst in pieces it'd be sourcing down larger pistons increasing capacity . Anyone's guess of how much ?? $8-12k +
Lastly what do you mean by a soured reducing valve was the case did the mechanic say this and how did it get there
Old May 10, 2019 | 03:16 AM
PaiMai's Avatar
Yes, now the engine is ready to pull out from the car. I think that in 2-3 days it will be already possible to examine the engine from within.
Old May 10, 2019 | 03:19 AM
PaiMai's Avatar
Could tell me please, cranks in 4.2 are tempered by currents of high frequency?
Old May 22, 2019 | 08:29 AM
PaiMai's Avatar
Steve will you give me advise please! Bolts on engine 4.2 disposable? Usually what bolts need to change at capital repairs?
Old May 22, 2019 | 09:37 PM
steve_k_xk's Avatar
Whilst the engine is in pieces I would take a look at the timing chain guides if there is any wear replace .
Also replace the water pump whilst engine is out
Obviously new head gaskets and head bolts will also be required
Bottom end bearings will should also be replaced on the rebuild
Old May 24, 2019 | 02:37 PM
PaiMai's Avatar
Thanks! I will follow your advice.
Danesh sovo
Apr 2, 2018 10:59 AM
Smudge67
Dec 31, 2017 08:09 PM
AP3
Oct 13, 2014 02:49 PM
Cajun Mojo
Mar 14, 2008 08:09 PM
