New 200 cell CATS
Old May 30, 2019 | 09:00 PM
badicedog's Avatar
Originally Posted by Stuart S
Thanks, Q&C. I'm still waiting for the OP to respond to my Post #8, above, in which I stated: "Please read my post again and explain to me exactly what I wrote that was offensive to you. Your attack on me is unfounded." No response tells me that I would be wasting my time to be condescending to someone who doesn't get it.
Yes, you're right - he is the pilgrim who is leading the charge to show us the way. LMAO! His problems so far tell me that those 200 cell cats are the wrong way! They'll work, eventually, given enough of his time and his money.
So now I’m a fool? I’m not going to get in a pissing match with you. We have a difference of opinion and I’ll leave it at that.
Old May 30, 2019 | 10:09 PM
badicedog's Avatar
So now I’m a fool? But you are not condescending right? You offer no suggestions just that I’m doing it wrong and it won’t work (200 cell cats). I know this is an online forum, what a way to welcome new members. We just have a difference of opinions, I’ll leave it at that.
Old May 31, 2019 | 06:56 AM
Stuart S's Avatar
You accused me of being negative towards you, which I denied. If you had replied, this never would have happened. Don't blame me. Blame yourself.
Old May 31, 2019 | 07:17 AM
badicedog's Avatar
Grow up! Like how old are you? Geesh. I don’t play the blame game. Moving on!
Old May 31, 2019 | 08:42 AM
Stuart S's Avatar
Actions have consequences. 'Nuf said.
Old Jun 3, 2019 | 03:59 PM
badicedog's Avatar
Update... ECU tune done! Car is performing better then expected. Increased torque/power across powerband. CEL still one due to O2 sensor placement. Will have them moved directly unto rear of CAT instead of 1-2 inches downstream of CAT. Finicky Computer is reading Low Voltage. Will update progress. Big thanks to AlexJag for the tune.
Old Jun 3, 2019 | 09:03 PM
Ranchero50's Avatar
From what I read and understand the 139 and 159 codes were sign of the sensors themselves failing and not cycling quick enough. It wasn't necessarily a tune issue, just the way the sensor was supposed to cycle between high and low readings X number of times within Y number of seconds. Mine went away once I replaced it.
Old Jun 3, 2019 | 09:26 PM
  #28
badicedog's Avatar
I had my muffler guy reposition the Dow stream O2 sensor directly on the CAT. The CEL has gone away. This car has less the 18k miles on it. I got the codes when I switched to the Hi Flo cats. For what ever reason the ECU did not like the position of the downstream sensor(2-3 inches from CAT).
Old Jun 3, 2019 | 10:49 PM
AlexJag's Avatar
Sponsor
Good to hear, just as was suspected ! Cel light for high flow cats is taken car of in the tune so you should not get anything pooping up now . Enjoy the new added power 👍!!!
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
abs777
Feb 10, 2017 02:29 PM
kj217
Sep 7, 2014 04:10 PM
Maxville
Jun 27, 2014 12:40 AM
rocklandjag
Sep 24, 2010 10:07 AM
