New jag xk owner
I am Steve, from Canton, Ct, we are picking up a 2013 XK as soon as the weather clears up here. The car came from Long Island, NY with 22,900 miles.
I have read about the battery problems and tenders. I will be installing one as soon as we get the car. CTEK seems to be recommended, but which model ??
The dealer is installing a new battery for us, as the car would not start when we wanted to test drive!!!! (top was down !)
Might using a tender be a false sense of security? We are planning on a two week trip late June, and plugging in every night might not be possible.
Thanks in advance
Steve
Thanks in advance
Steve
Thanks in advance
Steve
Thanks in advance
Steve
A lot of people rave about the AGM style batteries. I would go with one of them if it's not too late. I never had problem with the battery if the car is locked and driven at least ever 4-5 days. CTEK dongle can hide of pop out of spare tire panel. Car will start after months on a CTEK like you left the car for a long weekend.
You may want to consider a brake fluid flush even if you got to pay out of pocket...
You can use any 12v.model of the CTEK range. They all do the same thing; I have used both the cheapest and the most expensive, both with perfect results. Using the CTEK maintainer does not give a false sense of security - it merely makes sure your battery is at optimum charge level and that therefore the electronic modules on your XK will operate as designed. You need not worry about using your XK on a trip without the CTEK. The driving itself will keep the battery (assuming it is good) at proper charge. The electrical problems come on cars used infrequently and/or used for short trips. The battery eventually loses sufficient charge to keep the XK modules happy. And, for the record, this is not a "Jaguar problem". All the premium automobile manufacturers recognize this concern and all of them market chargers (the CTEK units!) self branded.
You will LOVE your XK. Do check the forum for questions related to the 5 litre engine.
Welcome aboard you are in for some good times. sov211 is absolutely accurate in his comments above. I a remote top opener device installed in my vert and I highly recommend it, particularly with the rear window control accessory. The modules are made and marketed by the Jag Wrangler, he is a member of this forum, makes an excellent product and is a good guy. his handle on the forum is white xkr and his website is TheJagWrangler - Home - About Us.
I only use the Ctek if I am away for more than 5 days or occasionally in the Winter when the touch screen stays on the Jaguar Home Screen. The car will always start so you wont get let down imo
Don't be paranoid over battery and electrical issues. As mentioned above you only get issues if car is used infrequently or you have an old or faulty battery.
Odd issues that occur and mentioned on here are mostly suggested that the battery is the problem.
Just for an instance my 2006 XK convertible that I have owned for 4 years and I do not use a battery changer or conditioner has never had an issue.
It is used probably 2 - 3 times a week to go the golf club which is a 25 mile round trip.
It is kept on my drive with a half cover. I do not know how old the battery is.
I go on 2- 3 week holidays and the car always starts when I return.
This type of car is often used infrequently so if that will be the case then a maintainer is recommended. But if used daily or a few times a week and not just a short trip down the road and you have a new battery then don't worry about it and just enjoy owning and driving it.
Just be aware that if you start getting obscure and odd ball messages then reflect on your usage and there is a good chance that it could be the battery
Enjoy
Enjoy
I sure appreciate all of the info, I'll order one when i pickup the car. I have looked around this site, and its seems like to be very informative for all things Jaguar !
Are there many members or events in the Ct region?
Steve
Steve
A few details to look at when picking up your car. Make sure the convertible top works perfect when opening and closing and that the windows open and close properly as well. Also make sure the seats recline as far back as they should and that all seat functions work perfect too. Also check all the steering wheel buttons and the touch screen [heated seats, nav, radio, connect your cell phone...etc]. '
Let us know how it all works out.
Funny thing , because of the uniqueness of the XK there are usually not to many people in rural areas that have them. I remember when I bought my Ferrari I thought there were far and few between owners. Well I found out that there were 10 in my local county and 4 of them were in my town of 9,000 people. Now with the XK after 2 years of ownership I know of 3 in the county and none in my town. I asked my insurance agent to check their system to see how many are registered in the area. I would suggest you check with your state Jaguar Club and see where they meet.
