new member - 2007 XK
Old May 23, 2017 | 08:16 PM
potomacmidget's Avatar
Default new member - 2007 XK
Dear All,
I purchased a 2007 XK the other day, with 61K miles, very clean - everything appears to work except the radio antenna; it appears in the down position at all times. I assume it should extend when the radio is powered? Any advice appreciated on how to troubleshoot.
Old May 23, 2017 | 08:46 PM
pwpacp's Avatar
If you don't hear the antenna trying to extend it has probably been disabled. Check fuse #4 in the back seat fuse panel (pull and lift the center seat panel between the seat backs). The fuse might be missing to interupt antenna motor power. The fuse could also be blown as well and the replacement should be 10amp.
This information pertains to the convertible model but is porbably the same for coupe too.
Welcome to the club!
Old May 23, 2017 | 09:30 PM
Smile
Thanks! looking forward to learning a lot on this forum and checking out this cool car (its my wife's new toy but she is sort of afraid to drive it going from a 4ycl to a V8 so I will cruise around in it until she takes it back....)
Best,
Reg
Old May 23, 2017 | 09:39 PM
tberg's Avatar
Welcome aboard, but without pictures, we don't believe you! Have fun!
Old May 23, 2017 | 09:46 PM
Picture! Its real!
Old May 24, 2017 | 10:28 AM
shemp's Avatar
Very nice!!! On the Antenna, a lot of people remove the fuse so the antenna does no go up, so check that first. Lots of '07 owners here so someone will chime in on the fuse location. If not, search the forum and it will come up.
Old May 24, 2017 | 11:08 AM
JackJohn's Avatar
The antenna mast fuse is F4, found in the rear seat compartment. Pull sharply on the top center of the rear seat and when it pops loose lift up to remove.
Old May 24, 2017 | 07:41 PM
Ranchero50's Avatar
What color is it? Interesting to see so many MD cars showing up.
Old May 24, 2017 | 10:09 PM
myexcursion's Avatar
Congrats on the new ride ! Looks great !!
Old May 25, 2017 | 05:18 PM
Hi All,
Thanks for the guidance, I found that the fuse space was empty and I installed a new fuse and the antenna powered up, so thanks again!
On another note it is british racing green.
I have a new problem but will start a new post....
Old May 25, 2017 | 10:27 PM
ralphwg's Avatar
Nice ride. Welcome aboard.
Old May 25, 2017 | 10:44 PM
michaelodonnell123's Avatar
Beeeeuuuutiiiifulllll Jag you have there!
Old May 25, 2017 | 10:54 PM
Backyard Buddy's Avatar
Very nice!!! Congratulations!!!
Old May 30, 2017 | 05:04 PM
ferraripete's Avatar
keep the antenna disabled. invest in some good cd's or get sat.
Old Jun 2, 2017 | 11:56 AM
mij86's Avatar
Nice wheels, I'm waiting delivery of my 2007 XKR and have been reading with interest on the rear antenna or across the pond we call it an aerial I'm going to disable it and try to install an alternative one
Old Jun 9, 2017 | 12:19 AM
Fstbmw1's Avatar
Originally Posted by potomacmidget
Hi All,
Nice car... I also have an 07' and pulled the antenna fuse in order to prevent it from rising, still get very good reception. Be wary should you ever use an automatic car wash and the radio is on.... trouble may occur. I was driving my car into my garage and was parking it beneath my car lift, antenna was up... it bent slightly but not damaged, Hence I pulled the fuse
Old Jun 10, 2017 | 11:00 AM
McJag222's Avatar
Nice...Jags not bad either..
2007 Rick
Sep 11, 2021 09:05 PM
Allante1989
May 23, 2017 05:06 PM
wsn03
Mar 9, 2017 05:20 AM
ralph81176
Jan 21, 2017 04:40 AM
XKR-NC
Jul 28, 2013 07:29 PM
