No power to sc intercooler pump when ignition is on
Old Jul 6, 2019 | 07:53 PM
AlexJag's Avatar
Sponsor
Default No power to sc intercooler pump when ignition is on, upgraded to Bosch 001
So I got to replacing my intercooler pump with the upgraded Bosch 001 pump. All went well but when testing power with ignition on I got none going to the pump . Any ideas? I checked fuse 24 under the hood, its all good.
Had the car running with new pump and dont notice any flow either. Is there a relay maybe?
08 jag xkr
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Jul 7, 2019 | 06:18 PM
8bit's Avatar
If you don't see a fault code then I'd say you have no fault. Use Torque Pro or similar and watch your IATs. If they stabilise and you don't end up in Restricted Performance mode after 20/30 mins of normal driving then you have no fault. When my pump failed that was exactly what happened, if yours isn't doing that then you likely don't have a problem.
Old Jul 8, 2019 | 01:07 AM
AlexJag's Avatar
Sponsor
Hmm all service manuals I find tell me, power is on with ignition.
Old Jul 8, 2019 | 11:41 AM
Ranchero50's Avatar
http://jagrepair.com/images/AutoRepa...79toB09096.pdf
Page 4.7 shows the electrical schematic for the cooling system.
Old Jul 8, 2019 | 01:40 PM
AlexJag's Avatar
Sponsor
Iv seen that , does it tell you the power is on with ignition on? I cant figure it out
also relay r12b is nowhere to be found
Old Jul 8, 2019 | 03:58 PM
Ranchero50's Avatar
Index says LH suspension turret under the hood so it should be in there.
Old Jul 8, 2019 | 10:58 PM
AlexJag's Avatar
Sponsor
Thanks yes I know it should be here
but all I see are relays r5 r7 r8 no r12,
Old Jul 9, 2019 | 06:14 AM
Ranchero50's Avatar
Thinking about this I think I was there a couple months ago and I think the relay is internal to the module. You can pull the F24 fuse and should measure 12v on one leg.
Old Jul 9, 2019 | 12:36 PM
AlexJag's Avatar
Sponsor
Yes I checked 24 there's no power. so I'm suspecting most likely is that coolant pump is not on with the ignition but only on certain conditions. so if it's internal relay where would that be?
Old Jul 9, 2019 | 01:03 PM
Cee Jay's Avatar
One would assume that it would be thermostatically controlled. No sense in circulating already low temp coolant.
....but where....................
Old Jul 11, 2019 | 12:02 PM
AlexJag's Avatar
Sponsor
I did more testing and yes the pump works on certain conditions, but not that with ignition on. Not sure why the service manual says otherwise.
I'm planning to rewire soon to have it on all the time on ignition
Stumpy
Jul 13, 2012 01:10 PM
sivkov-y
Feb 24, 2011 02:33 AM
SteveM
Oct 12, 2010 09:57 AM
WinterJag
Apr 26, 2010 05:26 PM
