Obscure question, suspect someone knows
Old Jul 2, 2021 | 02:06 PM
Andy M's Avatar
Default Obscure question, suspect someone knows
Looking to see if my trusted local mechanic would be able to work on a XK. His concern is that his lift connects with the car via a frame point not a suspension point, and that could damage the Jag. Thanks if anyone has any idea!! Andy
Old Jul 2, 2021 | 02:29 PM
Cee Jay's Avatar
There are factory lift points on every car I've ever seen. I think there's even a Sticky in this forum about it for raising XKs.
Old Jul 2, 2021 | 09:32 PM
jahummer's Avatar
There're small triangles on the undersides of the rockers which point to the location of the lifting points.
Old Jul 3, 2021 | 04:52 AM
+1
There is.
See SECTION 9 MAINTENANCE: Jacking the vehicle - axle stand points
https://www.jaguarforums.com/forum/x...enance-227403/
Old Jul 6, 2021 | 10:50 AM
JoeLanger's Avatar
take it to a different garage if that's what he's asking
Old Jul 13, 2021 | 06:14 PM
GordoCatCar's Avatar
Default I have been lifting like this on all my cars using four rubber cushiions
I use four rubber blocks 2x4x6 , Two each on either side of the chassis rail, I try to get as close to possible to the lift points, but on the Coupe it is always resting on the molded rocker panel being supported underneath by the unibody chassis. I 've done this for years on all of my cars and never had an issue... even on cars with pinch welds.
fmmsr45
US Lower Atlantic
Jun 22, 2015 05:47 PM
EcbJag
Feb 8, 2013 12:18 PM
avt007
US Southwest
Jan 13, 2013 06:36 PM
user 2029223
Dec 7, 2011 05:34 PM
