Overhead console colors
Old Sep 11, 2020 | 05:20 PM
XabXab's Avatar
Default Overhead console colors
Is there only a beige overhead console for the 07-09 XK? Will the consoles from the later models fit? Getting the headliner replaced with black and I'd like to find a black console.
Old Sep 11, 2020 | 07:09 PM
JackJohn's Avatar
I've never seen but the beige console. You could wrap it.
Old Sep 11, 2020 | 08:48 PM
Stuart S's Avatar
I'd spray it with a rattle can of black paint designed for use on plastic. You might need a primer for the best adhesion.
Old Sep 11, 2020 | 08:51 PM
XabXab's Avatar
That's what I was thinking. Sand, prime, sand, paint. Thanks for the info!
Old Sep 12, 2020 | 07:26 AM
jahummer's Avatar
It is available in Canvas and Charcoal
Old Sep 12, 2020 | 05:56 PM
JackJohn's Avatar
There you go, it is available in charcoal. That will cover your needs. Just be sitting down when you find out what it cost.
Old Sep 12, 2020 | 07:09 PM
jahummer's Avatar
On eBay frequently
Old Sep 14, 2020 | 10:55 AM
XabXab's Avatar
From what I can find, the ebony version of the console is 2012+ only and not compatible with older versions. There's only one part number for the console for the coupe from 07-09.
Old Sep 14, 2020 | 12:07 PM
Stuart S's Avatar
Instead of my suggestion in Post #3, you may want to use Plasti Dip. If you don't like it, it peels off. Read the Q&As and customer ratings.
Amazon Amazon
Old Sep 14, 2020 | 01:55 PM
jahummer's Avatar
When I changed the failed interior bits, I also changed from Canvas Alston suede to Jet Alston Suede. Ordering new charcoal hardware such as hooks, caps etc was cheap and easy. The overhead console was expensive new and I didn’t want to hassle with hunting for one on eBay so I completely disassembled mine. It was quite easy to do and I used SEM black plastic dye. Came out looking like it was made that way and five years later it still looks new.
However there should be no reason why a 2012+ one won’t fit, just make certain which version you get - convertible vs. coupe, PDC buttons, etc.
spindoc
Jul 4, 2017 01:21 PM
Don-T
Jun 11, 2017 07:19 PM
Brian M Williams
Jun 16, 2013 07:12 PM
elwoodboll
May 31, 2013 05:07 PM
Raheny
Jun 23, 2009 10:13 PM
