P0087 Live readings during restricted performance mode
Old Sep 16, 2024 | 11:37 AM
Groovn3's Avatar
Default P0087 Live readings during restricted performance mode
Just picked up a XKR 2010 5.0 Supercharged, drives fine no issues but when I go on cruises and want to push it, ill get on the throttle
kind of heavy and then enter into a limp mode with restricted performance no check engine light and if I press on the gas itll eventually turn check engine on. When I pull over, turn car off and let sit for 5 min and ecu reset with my reader it drives like nothing every happened and code clears.
I have attached live readings of what I got during this, if anyone can take a look, came to the conclusion its probably a high pressure fuel pump issue, it has good pressure when idle but upon reading forums seems like a fuel pump or high pressure issue. Next option is to have someone can with SDD to really test it is what I heard they can see using that software.
Old Sep 16, 2024 | 12:20 PM
sony2000's Avatar
This may be the cause of your low pressure. If not, things get more expensive.
Old Sep 16, 2024 | 01:45 PM
Groovn3's Avatar
Default do this first
https://www.youtube.com/watch?v=U0PxtnnYdJs
I should probs do this first as this seems the most economic option along with fuel regulator, is taking to jaguar for a diag worth it in this case
Old Sep 16, 2024 | 03:59 PM
sony2000's Avatar
For the few $ it takes, and often this is the culprit, just go ahead and change it, Delphi has aftermarket economy parts for this. Napa or even eBay these days. I am having hard time finding it on a parts list. I think it is still being used. .
Old Sep 16, 2024 | 05:34 PM
SNAPCHAT's Avatar
I got the same code and limp mode and the whole 9. Mine is a 2012, but ended up being one of the 2 HPFP's. I have a thread on doing the repair on my profile, its rather DIY. Fuel pump costed me like $115
Old Sep 17, 2024 | 05:40 AM
sony2000's Avatar
If you use the dealer, go there. If you have an independent garage, he can do it. A cheap fix could be to change the fuel filter, or fuel pressure sensor.
Don't go into the gas tank too quickly. =$
Old Sep 17, 2024 | 06:42 AM
guy's Avatar
guy
Incidentally, your ODBII reader states there are 2 DTCs thrown. What is the other DTC please?
And fwiw, there are 3 tests prior to replacing the sensor.
Cheers!
Old Sep 17, 2024 | 09:00 PM
xalty's Avatar
take the vac pump off put it in timing position
if the aux shaft alignment tool doesn’t fit the chain jumped
Jaglover456
Dec 5, 2023 04:27 AM
Bret_T
Mar 24, 2023 08:32 PM
K.Lewis
Jul 21, 2020 06:30 AM
Aarcuda
May 1, 2020 05:44 PM
DCJAGMAN
23
Jan 7, 2019 09:11 PM
