Paint peeling on shifter console plate
Old Jun 25, 2017 | 12:40 PM
Ric Gallaher's Avatar
Default Paint peeling on shifter console plate
Hi
my console on 2007 xkr is peeling any ideas other replace whole part. Here is a picture
Old Jun 25, 2017 | 01:28 PM
Patrick Wong's Avatar
On my 2007 XK, the chrome partially peeled off at the gate near the "D". I don't even think you can buy that part; at least I was not able to find it in the Jaguar online parts catalog.
Old Jun 25, 2017 | 04:14 PM
davchr's Avatar
That is part of the gearshift assembly, P/N C2P5184. You don't even want to ask what the list price is. It is not obvious from the drawings that it can be easily removed for restoration.
If it can be removed I would probably artistically mask over the P R N D and S and repaint the rest of it. Sand and feather the damaged area first.
Or paste a Jaguar leaper or growler logo over the damaged area.
Old Jun 25, 2017 | 04:20 PM
ralphwg's Avatar
That was a fairly common problem with 2007-2009 XKs. I had the same problem three different times with my 08; all repaired under warranty. since you are no doubt off warranty, suggest you look for a disassembler such as Pacific in the Detroit area or Century in SoCal. Or, you can google Jaguar disassemblers and see what you come up with.
Old Jun 25, 2017 | 09:08 PM
Queen and Country's Avatar
Here is what I would do.
Put 3m brushed black wrap on the entire thing, and leave the areas with the letters open. It will actually be an upgrade.
Any good wrap shop will be able to do it for you.
The price of the material is $3
They wrap entire cars in it and it looks very good, feels good too.
Old Jun 26, 2017 | 11:27 AM
aacpa15215's Avatar
Thanks. I have the same problem with my 2008 XKR. Will pursue the suggestions. Is a Wrap shop same as upholstery shop?
Old Jun 26, 2017 | 11:43 AM
No. Vehicle Wrap shops are all over every city, its a paint alternative. Just do a Bing search and you find several in your area.
Incidentally, it will wear much better than original paint.
This is the type of store you need.
AZ Car Wraps - Phoenix Arizona Car Wraps
Old Jun 26, 2017 | 01:21 PM
myexcursion's Avatar
Do they have to pull the trim off all around it / remove the shifter, or do they typically go right over the whole shifter and trim around ?
Old Nov 17, 2022 | 01:05 PM
malcolmgilbert's Avatar
Default Peeling Trim Plate Solution
Hello,
A customer refered me to this website. Here is a link to our website where we sell aluminum trim plates: www.solarsigna.com
Best regards,
Malcolm
