Passenger Door Seat Control Board
Old Feb 24, 2020 | 05:37 PM
malx's Avatar
Default Passenger Door Seat Control Board
Hi!
2010 XK Coupe here!
So I noticed that the passenger door lights where the seat controls are, were out. I assumed maybe it was a small light that needs to be replaced but turns out it's a bunch of LEDs that are attached directly to the circuit. I'm assuming that the entire board is dead. Has anyone experienced this and can help walk me through the steps at correcting the problem?
Thanks!
Old Mar 1, 2020 | 04:59 PM
Don-T's Avatar
I hate to be the bearer of bad tidings but, as a former electronics tech, your chances for repair are slim. If a careful visual inspection using a magnifying glass and good light doesn't show a crack or burning somewhere and the connections are good, you will need specialized test equipment and a schematic to figure it out. The probability is that one of the thousands of semiconductors grown on one of the IC chips died and the chip needs replaced. That also requires special equipment. Best bet is a salvage yard swap.Good luck.
Old Mar 2, 2020 | 08:50 AM
barnsie's Avatar
The seat control panels are available on eBay, but are not all that cheap:
https://www.ebay.co.uk/p/11029426167...hoCpzMQAvD_BwE
This one is a lot cheaper and from the older model:
https://www.ebay.co.uk/itm/Jaguar-XK...IAAOSwe9tcbBhy
It is worth inspecting the original closely - if it's just the track that has burned out for some reason it's easy enough to repair. If it's one of the thousands of individual bits, as Don-T says, the only way forward is a replacement. Or, since it's the passenger side anyway, just ignore it
Old Mar 3, 2020 | 07:53 AM
malx's Avatar
Thanks everyone! My car only has 12,000 miles on it and it's like brand new, so it's worth repairing. The part is 260 here in the US so it's a bit cheaper on Ebay however, once you add exchange rate and shipping, might as well just get the part from the dealer and toss it on in case I have issues I can point back to them.
Will inspect the bits later and see if anything.
Old Mar 3, 2020 | 07:57 AM
barnsie's Avatar
You can also buy the part from eBay USA....
https://www.ebay.com/itm/11-12-Jagua...UAAOSwPCtc-BmR
https://www.ebay.com/itm/09-Jaguar-X...MAAOSwEJZdMsb6
Old Mar 4, 2020 | 06:12 AM
guy's Avatar
guy
Are you certain it’s the board that’s the issue... that’s quite peculiar.
Id be checking power to the door, connector first.
Takeo
Aug 20, 2017 06:53 PM
Peter's s type
Jun 11, 2015 04:51 PM
04xtype04
Feb 6, 2014 02:24 PM
robsxjs
Jul 18, 2013 12:57 AM
jjrglobal
Apr 2, 2011 12:32 PM
