Plastic Rattle Under Instrument Panel
Old Jan 11, 2024 | 01:55 PM
ptaylor2000's Avatar
Smile Plastic Rattle Under Instrument Panel
My 2011 XK coupe has a rattle from the instrument panel area when traveling on even mildly bumpy pavement.
I tried to isolate the vibration to the plastic instrument cover, or the trim in that area, to no avail.
Because it is dangerous to be poking around the instrument cluster while driving down the road, I thought it better to ask if anyone has solved this problem, or for directions on what I might search for to correct it.
My Jaguar mechanic friend's advice was simply: " Just turn the radio volume up!"
I am looking for something a little bit more constructive.
Old Jan 11, 2024 | 02:42 PM
Cee Jay's Avatar
A 'hard' rattle, or a light one? Rattles that are in the suspension usually sound like they are in the dash area. You stated a Plastic kind of sound, so maybe not anyway.
Have you tried pushing against the binnacle while you hear the noise? Mine rattles there occasionally.
Old Jan 11, 2024 | 04:21 PM
kj07xk's Avatar
Could be some wires or wire loom that moves and bumps against something. Had any work done that could have resulted in wires being disconnected/connected? Poke you head under with a flashlight and wiggle stuff to see if anything makes noises.
pcolapacker
Jul 19, 2023 11:34 AM
BritCars
May 20, 2018 05:04 PM
JB600
May 5, 2014 07:14 PM
inertian
Sep 7, 2012 03:11 AM
npereza5
Apr 3, 2011 11:53 AM
