Quick check lug nuts
Old Jun 13, 2015 | 03:07 PM
jagtoes's Avatar
Default Quick check lug nuts
I couldn't find the torque requirements for my 2012 XKR wit 20" Nevis wheels. I used 80 Lb. Ft. but was wondering what the spec is. Any assistance would be appreciated. Thank you.
Old Jun 13, 2015 | 03:37 PM
Stuart S's Avatar
jagtoes,
I'm pretty sure it's 92 lb.-ft. I'll try to find the spec sheet.
Yep, it's in the Owner's Handbook for my 2009. Same for 2012. Here's a copy of the text from the 2012 Owner's Handbook: http://topix.jaguar.jlrext.com/topix/content/document/view?id=157281¶meters=highlight%3Dwheel%20torque%2 6openProcedure%3D8bb4b336-47c0-49d6-958e-4cc9f9476e62
Tightening the wheel nuts
Using the wheel nut wrench, lightly tighten the
wheel nuts alternately using the sequence
shown in the illustration.
Lower the jack and tighten the wheel nuts
alternately. Do not over
tighten by using foot
pressure or extension bars on the wheel nut
wrench.
At the earliest opportunity have the wheel nuts
tightened with a torque wrench to 125 Nm
(92 lb.ft).
This torque must not be exceeded.
If this was helpful, please click at the bottom right of this post.
Stuart
Last edited by Stuart S; Jun 13, 2015 at 03:51 PM. Reason: Added spec from Owner's Handbook
Old Jun 13, 2015 | 06:42 PM
jagtoes's Avatar
I couldn't get to my OM but did a little web searching and found 125NM (92#ft) so I adjusted accordingly and am good to go. Thanks.
Old Jun 13, 2015 | 11:11 PM
richzak's Avatar
I am certain that Stuart S. is CORRECT w/ 92 lbs.
aholbro1
Dec 29, 2024 06:46 PM
Neil1664
Jan 20, 2022 08:59 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
joesoap
Sep 10, 2015 01:09 AM
Mosers63
Sep 6, 2015 02:53 PM
