Radiator fans and Check pedestrian system / front parking sensors
Old Jan 6, 2018 | 08:44 AM
Ranchero50's Avatar
Ditto what Peter said. Once you can read the codes, swap the components around to see if the fault follows them or is something else. Much cheaper vs. shot gunning parts at a problem.
Old Jan 6, 2018 | 08:46 AM
trofeo2016's Avatar
Righto. This is sound advise.
Cant thank you all enough.
will report back in a week or so when i have the bumper off and scanner in hand.
Old Jan 6, 2018 | 08:53 AM
Ranchero50's Avatar
Oh yeah, a lot of these generation Jag parts are Ford sourced so don't be afraid to shop around for different prices. No need to pay the luxury surcharge for the green and white box.
Old Mar 15, 2018 | 07:51 AM
jima's Avatar
Originally Posted by peterv8
Or buy an Icarsoft or foxwell scanner and you can find out which sensor it is, they cost around the same as one trip to a dealer!:-)
I have the Icarsoft LR2 and I also had the pedestrian warning but with the Icarsoft it told me which sensor was failing!:-)
Hi, I have a Pedestrian Warning so I have just got an iCarsoft LR2 but I'm not clear on which option it is. Looks like it should probably be ICS (Impact classification system). Can you confirm please?
Old Mar 15, 2018 | 11:02 PM
peterv8's Avatar
Don't remember, just go into that option and let it scan.:-)
Old Apr 8, 2018 | 04:54 AM
Dave50's Avatar
Default Icarsoft 2
Hi any luck with the scanner? I have just got the icarsoft 2 scanner myself & have the same pedestrian warning light on . Any information on how to find the code would be much appreciated.
thanks dave
Old Apr 8, 2018 | 01:35 PM
jima's Avatar
Originally Posted by Dave50
Hi any luck with the scanner?...
Yes, this is where I have got to so far. I have shown the full sequence in case it is of interest to others. You can see DTC B1004 - right impact sensor on the 10th image. Like apparently many non-SDD systems the last two digits are not shown so there is no information as to the exact fault and B1004 has about 8 sub-codes ranging from various shorts, no/erratic signal etc. Reading the data stream though (15th image) shows the right sensor to be slightly higher resistance compared to the left sensor so my next step will be to clean up contacts then if that doesn't rectify it then replace sensor (or the pair) but as others have commented that this required nose-cone removal on supercharged models I am manfully putting the job off until it stops raining and warms up a bit (the XK8 is hogging the garage space without a serpentine belt so can't move her yet). I'll report progress back here as and when. Glad I bought the LRII though
Attached Thumbnails Radiator fans and Check pedestrian system / front parking sensors-p4081367.jpg   Radiator fans and Check pedestrian system / front parking sensors-p4081368.jpg   Radiator fans and Check pedestrian system / front parking sensors-p4081369.jpg   Radiator fans and Check pedestrian system / front parking sensors-p4081370.jpg   Radiator fans and Check pedestrian system / front parking sensors-p4081371.jpg
Radiator fans and Check pedestrian system / front parking sensors-p4081372.jpg   Radiator fans and Check pedestrian system / front parking sensors-p4081375.jpg   Radiator fans and Check pedestrian system / front parking sensors-p4081376.jpg   Radiator fans and Check pedestrian system / front parking sensors-p4081377.jpg   Radiator fans and Check pedestrian system / front parking sensors-p4081378.jpg
Radiator fans and Check pedestrian system / front parking sensors-p4081379.jpg   Radiator fans and Check pedestrian system / front parking sensors-p4081380.jpg   Radiator fans and Check pedestrian system / front parking sensors-p4081381.jpg   Radiator fans and Check pedestrian system / front parking sensors-p4081382.jpg   Radiator fans and Check pedestrian system / front parking sensors-p4081383.jpg
Old Apr 8, 2018 | 01:48 PM
  #28
Dave50's Avatar
Yes, this is where I have got to so far. I have shown the full sequence in case it is of interest to others. You can see DTC B1004 - right impact sensor on the 10th image. Like apparently many non-SDD systems the last two digits are not shown so there is no information as to the exact fault and B1004 has about 8 sub-codes ranging from various shorts, no/erratic signal etc. Reading the data stream though (15th image) shows the right sensor to be high compared to the left sensor so my next step will be to clean up contacts then if that doesn't rectify it then replace sensor (or the pair) but as others have commented that this required nose-cone removal on supercharged models I am manfully putting the job off until it stops raining and warms up a bit (the XK8 is hogging the garage space without a serpentine belt so can't move her yet). I'll report progress back here as and when. Glad I bought the LRII though
Thanks jima this is excellent. Your a star
Old Apr 8, 2018 | 04:00 PM
Cee Jay's Avatar
......... Glad I bought the LRII though
Hey, does that LRII allow changes to the CCF? I need to turn on my rear view camera, and even the (very worthless) dealer can't do it.
Old Apr 9, 2018 | 02:24 AM
  #30
Parzival's Avatar
I had the same issue with the pedestrian sensor.. the readout for me was:
B100431 - Right pedestrian protection accelerometer - No signal
B100496 - Right pedestrian protection accelerometer - Component internal failure
While Jaguar quoted me over $2000, a local mechanic managed to swap the sensors from another car and only charged me $60.
Old Apr 12, 2018 | 04:53 AM
  #31
jima's Avatar
What was used to get the readouts? The full 7-character codes are really useful, the '31' and '96' giving the fault detail that many if not most third-party tools don't seem to. Does anyone know if Autoenginuity gives full codes?
Old Apr 30, 2018 | 10:08 AM
  #32
jima's Avatar
Apologies, I missed this. I'm not sure, I will check but that sounds like SDD territory to me.
Old Apr 30, 2018 | 10:14 AM
  #33
jima's Avatar
Well, the contact cleaning didn't cure the problem as it came back about four days later. Fortunately I had already decided to acquire a replacement sensor which cost the princely sum of $20. Over a week later and no faults, see the whole story here https://www.jaguarforums.com/forum/x...t-67933/page2/. Oh! I did not have to remove the nose-cone, only the radiator shroud.
Old May 9, 2018 | 02:54 PM
  #34
jima's Avatar
Just a final report to close off - still no impact system DTC's. Thanks to GGG who has pointed out that if you buy a new single-hole sensor you have to drill a new hole and that may well mean nose-cone removal to get clearance for the drill.
Disclaimer: a $20 sensor off a wreck is a bit of a gamble and it may only have a partial life left but if you choose carefully and avoid front-enders you may get a few (or more) trouble-free years.
moar
Jul 31, 2025 01:12 PM
Redescape
Jul 13, 2020 07:59 AM
Michaell
Jan 26, 2015 08:53 AM
jimboire
Oct 26, 2014 02:32 PM
stubbdog
Jun 11, 2014 04:56 AM
