Rear end hops
Old Apr 11, 2014 | 02:58 AM
Ngarara's Avatar
Originally Posted by SoCal Babe
I never thought about the flex in a convertible. that is a great insight to the possible problem.
Jag verts have generally had a good rep for minimal scuttle shake, and the XK is even stiffer than previous designs. It's not impossible that there's a small amount of flex, but I think the previous suggestions about the dampers are far more likely. As far as the stock dampers (and the Active Dynamics software that controls them) are concerned, you're running the car much nearer to full compression than normal, and the system just can't handle it fully.
Old Apr 11, 2014 | 08:20 AM
MaximA's Avatar
The full compression of the damper and also the fact the ADS can only increase damping to a certain point, which is right on the edge of not being enough.
This was my number one gripe with the base XKR suspension at higher speeds.
Old Apr 11, 2014 | 08:54 AM
MaximA's Avatar
SoBal Babe- Get in contact with Matt from Sprires in the UK Spires :: Engineered Performance for Jaguar and BMW
In my months of suspension trial and error, they are the only shop I've found to know their stuff with Jag suspensions. I'm sure the could suggest some dampers for you to try and alleviate the dreaded rear end bob.
Old Apr 11, 2014 | 05:37 PM
SoCal Babe's Avatar
ud
Smile
Thanks so much for steering me in the right direction . I really appreciate that!!
GordoCatCar
Jan 2, 2017 01:10 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
XKR-NC
Sep 4, 2015 08:23 AM
obwoodie
Sep 3, 2015 07:45 PM
