Reduced Performance Warning
Mine did that Restricted Performance right after I floored it to get around an idiot parked in the fast lane. Was it like SERIOUSLY restricted performance? I barely limped the couple miles home. You may have not noticed any smoke, but was there perchance a scent of gasoline (or petrol, you don't have your location posted)?
The problem I had was one bad injector, but all four on that side were replaced.
Cost me about two grand, and then I had a couple other things added in there also, like trans fluid, spark plugs and a few other minor items.
2007 XKR experiencing the same thing. Heavy acceleration, then suddenly winds down, Restricted Performance.
1. Replaced spark plugs based on engine code.
2. Next code was vacuum leak - replaced gasket connecting air intakes.
3. Garage said no codes, I picked it up, didn't even hit 50 mph before the engine sputtered and Restricted Performance.
Appreciate the other items to check. Taking it back to garage Friday to read new codes. Will check the battery and see if they can diagnose the intercooler and check the exhaust.
Also from re-reading I ought to have the injectors checked as well.
Thanks to all posting - these forums can be a life saver - and a wallet protector.
x350
21
Dec 29, 2020 06:49 PM
stevevaus
Mar 10, 2011 03:09 PM
