Remote and one-touch convertible top control works!!!!!!!!!!
Woohoo!!!!!
History was made tonight.
An X150 convertible top was controlled by remote control for the very first time.
I have built a working proof of concept system for operation of the X150 top with your remote control keyfob!!! Three presses of unlock on the fob opens the top and 3 presses of lock closes the top.
I purchased a 2007 XK with the express goal of achieving this (between drives
). This was a much more complex process than on the earlier X100. I will also be adding a one touch feature to the interior top button and possibly some other features.
Now on to turning the brassboard into a real product. Look for it in the coming months !
For those who might be interested, here is the original thread on the XK8/R forum that gave birth to the cool remote top feature: https://www.jaguarforums.com/forum/x...ou-want-53390/
Great job! Very impressive!
Since you mentioned the possibility of some other features, I was hoping that the backup camera retrofit would be the next challenge you would tackle, as you previously mentioned: https://www.jaguarforums.com/forum/x...etrofit-88209/
I believe the backup camera mod has excellent business potential since it applies to both convertibles and coupes from 2007 through 2009. Out of curiosity, I did an advanced search in the new XK/XKR forum for "backup camera retrofit" and found 3 threads with over 5,700 views! You might want to start a new thread to measure the level of interest. If you decide to do it, you can count me in!
Stuart
(note: quote edited and highlighted by Stuart S)
Stuart
Stuart
Stuart
Stuart
I am planning to soon investigate what the technical possibilities are for a well integrated backup camera. The limited rear visibility on these cars (especially the convertible with the top up) makes this a very desirable feature.
As has been discussed, the only external input to the factory video system is used for the navigation, and it is electronically switched in only when the navigation mode is selected. The key is to find either an alternate path to bring in video or to fool the system into going into nav. mode when the car is in reverse. I am not sure yet which is more feasible.
Not forgotten Norri, but I do need more people to buy my stuff. Then I can quit my day job and make Jag upgrades full time.
I am with you Stuart.
As you said when you started this thread: "Woohoo!!!!!
The bad part is not knowing how long it may take to bring the product to market. One wrinkle is that some of our cars came with OEM front and/or rear parking sensors that display a pictogram in the nav screen. It would be nice to be able to continue to hear the beeping (it accelerates as you get closer to an object) in addition to seeing what's behind you. I presume that the pictogram would be replaced by the rear camera view. My 2009 XKR Portfolio came with front and rear parking sensors.
I suggest that you consider starting a new thread for each of the pending products mentioned in this thread, including: (1) remote top; (2) backup camera; and (3) front park sensor. Doing so would help you separate and quantify the interest for each product, enable others who have the technical knowledge to brainstorm "how to do it" alternatives with you, and help you to determine the commercial feasibility. I wish I could do more to help, but electronics is over my head.
Stuart
Back to the topic at hand -- I'm in as soon as you've got a chip programmed and ready to go for the top down bit. I've installed mods similar to this in other cars to simplify life. I'm assuming you tap into the lock circuit for the initial stimulus then have a timer to press and hold the top up/down button after said stimulus. Sounds great -- I'm very willing to be one of the first!
" That's how I feel knowing that you'll be working on the backup camera retrofit!
Stuart
Stuart
Thanks Stuart. I sympathize with the frustration of having to wait. It does take a lot of time & effort to bring a solid, reliable product to market.
There is a fairly current thread on the backup camera in this forum which I have already mentioned my plans. I'll will update this thread once I have something new to report.
I plan to post sometime soon in the XK8/R forum some details about the front parking sensors.
You have the right idea, and you have described essentially how the older XK8 remote top works. On the X150 XK/XKR, you may have noted that the top does not normally operate with the ignition off. This, plus the security system added new wrinkles that needed to be solved.
The minute you perfect the Back-Up Camera Retro-Fit for a 2009 XK Coupe, I'll gladly be your first customer! Guys like you are the reason why I read this forum every day!
Hello, I was just about to send an email to see how the process was coming... congratulations.. just in time for summer....post a video.... when the product is ready for sale i'll be one of the first customers.
