Replacement fasteners...
Old Jul 12, 2025 | 06:03 PM
Speedmaster's Avatar
Default Replacement fasteners...
As in bolts...are you getting it from the dealer or is there an after-market source?
My fuel rail crossover feed line that has two bolts on the intake manifold is missing a bolt and it is driving me bananas. I want to replace it.
Old Jul 12, 2025 | 06:11 PM
Cee Jay's Avatar
I use a 'local' Bolt & Nut Supply Co. They have nearly every possible item. Check your area on Google.
Old Jul 12, 2025 | 06:44 PM
Thanks Cee Jay...I haven't done much Googling yet,this looks like a good find. Am searching my area now.
Old Jul 12, 2025 | 10:30 PM
farm-jag's Avatar
For the most part, with some exceptions, sure, bolts are bolts. They may not have the same exact head on them but finding the proper thread and pitch is pretty easy. Most hardware stores have that little board you can take another one in there and find what you need. Looks like you have another one right there to take to use to test with.
Old Jul 13, 2025 | 09:21 AM
clubairth1's Avatar
Community Influencer
This is another great example of why all Jaguar owners should get and install JPART!
If you want the correct part that's the place to start.
Diagram from JPART. Note item #9. Part #AJ812148 about $2 each from Jaguar. Yes that's a lot for one bolt.
Terry's carries it.
Bolt
When I see things like this it usually points to poor quality repairs and I hope your not missing even more stuff when you look closely.
Old Jul 13, 2025 | 09:53 AM
Terry's carries it.
Bolt
Tha@clubairth1 . Unfortunately, this is self-inflicted. I am relatively certain I dropped this into the lower cowl. I just wanted to replace the bolt rather than go looking only to find out it fell out after hitting a bump.
I have zero knowledge of jpart- is that downloadable? Up to now I’ve relied on the various websites and the repair manual.
Old Jul 13, 2025 | 10:16 AM
Sean W's Avatar
https://www.jaguarforums.com/forum/g...ighlight=Jpart
I think you still have to install the original JEPC (Jaguar Electronic Parts Catalog) but it no longer works because flash player has been discontinued. The new web version uses the parts and pics from the old version. The link above to the new version is under GENERAL TECH HELP. A search will get you to the old version too. Worth the effort imo.
Old Jul 13, 2025 | 10:48 AM
clubairth1's Avatar
Yes thank you for linking the JPART thread.
I have also been uploading the compressed archive for JEPC18 that is used with JPART.
Trying to keep it alive so I have uploaded it several times.
Old Jul 13, 2025 | 12:35 PM
@Sean W Thank you for this. I am reading it now, but I think I may be out of luck (I am an IOS user, not PC). Still, this may be worth dusting off an old laptop for the download.
Old Jul 14, 2025 | 12:57 PM
luv2fly's Avatar
Default Thread gages
Amazon Amazon
I bought this from Amazon and it's one of those things where you wonder why you waited so long to buy. It's come in handy so many times. There's a larger set on Amazon, too. Get the size and style of head and order several instead of $2 or 3 bucks each from Jag.
Old Jul 14, 2025 | 01:51 PM
Cee Jay's Avatar
When I want to use actual GOOD hardware, I always use ARP fasteners. That's what I have in my high performance stuff.
On the Jaguar, whatever fits and isn't crap does just fine. I do match within an area though.
Old Jul 14, 2025 | 03:14 PM
farm-jag's Avatar
Perhaps not worth it exclusively for JPart, but just good to know it is available in general, if you were not already aware.
https://www.parallels.com/products/desktop/
Old Jul 14, 2025 | 08:25 PM
@farm-jag Thank you!
bdobson
Oct 1, 2024 02:29 PM
Jrizzo003
Feb 10, 2024 01:33 PM
sbcbmx63
XJ XJ12 ( X305 )
Jan 28, 2024 08:44 PM
williamk123
Oct 15, 2023 03:51 PM
Svalbard
Jul 31, 2022 06:27 PM
