replacing battery in 2007 xk
Old Mar 30, 2018 | 05:21 PM
WRPDRYV's Avatar
Default replacing battery in 2007 xk
proccedure to replace battery in 2007 xk
Old Mar 30, 2018 | 05:36 PM
jagtoes's Avatar
The 1st thing to do is to put the new battery on a charger (10-20 amp) and charge it to it's full charge. Then the procedure is pretty straight forward just like any other car.
Old Mar 30, 2018 | 06:06 PM
Ranchero50's Avatar
Coupe or vert recovery is different.
Coupe, swap battery, reset window limits and go for a drive. Vert needs to learn the top logic as well and I'm not the guy to comment on that.
Old Mar 31, 2018 | 12:33 AM
kj07xk's Avatar
Nope, just reset the windows, that’s all I needed when battery replaced last fall on my 07 vert.
Old Mar 31, 2018 | 02:34 AM
JagV8's Avatar
Avoid doing it if smog is due soon as it clears all the OBD monitors (which need to be set for the check) and they may or may not be easy to set.
Old Mar 31, 2018 | 09:12 AM
NBCat's Avatar
A 'memory saver' device can also be used whilst replacing the battery to maintain audio, seat, window and OBD monitors.
https://www.ebay.com/itm/Car-OBD-Com...IAAOSw5VtZyMp1
Old Mar 31, 2018 | 09:15 AM
NBCat's Avatar
Or one such as this:
https://www.ebay.com/itm/Kastar-9-Vo...MAAOSwcBhWWJtl
user 84302
May 11, 2018 03:27 PM
jcberry
May 12, 2017 02:21 PM
rothwell
Feb 26, 2009 09:14 PM
JimC64
May 4, 2008 09:58 PM
