Replacing CATS shocks with normal ones
I'm considering replacing CATS shocks with conventional ones, but I don't know how they could be replaced without an alert appearing on the center screen.
Does anyone know how to do it?
The reason is none other than to value what CATS shock absorbers offer at the price they are selling, comparing them with normal shock absorbers in terms of performance and price.
Do the difference in vehicle performance with conventional shock absorbers or CATS really deserve that price difference?
and mount the conventional shock absorbers.
In this way it would not indicate any failure on the screen?
Go the BC coil overs I'm sure Jeremy can give you a run down on them
I've replaced my front shocks and tried 3 different spring combinations .
As I can see it will coil overs you have precise control of the height and damper rate resulting in better handling and also a positive weight reduction.
Another issue with the CATS system is when they fail they will revert back to the default mode being not soft which is quite comfortable but instead the firm mode which is bone jarring
Try disconnecting the cats and pulling the fuse. That should give you your answer inside of ten minutes.
Is this really your contribution to my question?
Why try to emulate when jahummer already provided you the solution in post #2 and #4. He speaks from experience.
In this forum I try to communicate by making my comment with the Google translator.
The same goes for the comments that you put the other foreros.
Sometimes this translation seems so strange to me that I can hardly deduce what you write in your comments.
Without going any further I can explain that when you talk about "gearboxes" it appears to me in the Spanish translation as "transsexual".
At first I was surprised since I thought you were talking about another topic since in Spanish a "transsexual" is a man who has changed his sex.
My sincere apologies to all for not understanding comments 2 and 4.
Thanks for the clarification
Sí, en serio. Quizás perdido en la traducción.Intenta desconectar a los gatos y tirar del fusible. Eso debería darle su respuesta dentro de diez minutos.Usando el traductor de google - espero que funcione
[CITA = Sean W; 2215151] Intenta desconectar a los gatos y tirar del fusible. Eso debería darle su respuesta dentro de diez minutos. [/ QUOTE]Excuse my expression.
I did not understand correctly your espilcacion.
Sorry I was rude.
correct and not failure or errors. It works perfectly. And yes I would highly recommend considering BC Racing coilovers.
