Safely jack up the XK/R
Old Oct 16, 2018 | 09:23 AM
Sean W's Avatar
Originally Posted by peterv8
I have a scissor lift and find it annoying to have to go down on my knee's to find the lifting points and to put a rubber puck in place.
Would this be okay on our cars and has someone used/uses them?
I use those same rubber plates on my XK but I slide them inward just past the outside edges of the rocker panels to avoid any pressure on them. They're large enough and cover the lift point. It's a non issue for me.
Old Oct 19, 2018 | 07:30 AM
peterv8's Avatar
Originally Posted by jagtoes
If you are distorting the plastic rocker panels then I would suspect that at some point you will crack them. These type of jacks are great but you should consider building a small jig out of wood with the jack points located on it .
Thanks but I want it to fit all my cars and don't want 5 jigs!:-)
Thank you, I've bought them!:-)
dpresent
Nov 4, 2017 01:04 PM
King Charles
Jun 30, 2017 05:41 AM
bil1024
Feb 2, 2017 06:16 PM
PapaSolo
Nov 13, 2016 04:46 PM
worrasf
Sep 20, 2014 08:31 AM
