Safely jack up the XK/R
Old Aug 3, 2018 | 05:17 AM
Ter11's Avatar
Default Safely jack up the XK/R
Hi all
I would like to jack up my 2011 XK to change the tires and do other work in the future.
According to the 2007 workshop manual (I only have this older one) the jacking points for the XK are the ones shown as “A” in the attached picture. “B” are the axle stand points.
My car did not come with a spare wheel and jack, only tire repair set.
But I have for my other cars a hydraulic pump jack, similar to the blue one depicted in the attached picture. Please also note the depicted black rubber cushion at the contact point of my jack.
To the ones here in the forum who do work on the XK themselves:
Will my equimpment as shown here work properly to raise the XK for tire change and similar work on the XK? In particular, is the rubber cushion suitable to raise the XK?
I plan to proceed as known from other cars: With handbreak applied and roadblocks under the opposite side front wheel, I would place the hydraulic jack with these rubber cushions at the “A” jack points and raise the car until the respective wheel clears the ground.
Any comments or advice in this context?
Many thanks!
ter
Old Aug 3, 2018 | 06:52 AM
Woo5ie's Avatar
Hi Ter, I think the jacking points in the diagram A are if you are using the supplied scissor jack.
I always use a trolley jack under the meaty parts of the chassis . It’s quite obvious if you have a look.
Be careful to clear the plastic sills when jacking up.
One of my jacks has the rubber pad and if I use the other one I pad it out with some old rag. Save marking the painted chassis.
Nothing special on these cars, same as every other one I have worked on.
Old Aug 3, 2018 | 07:18 AM
pwpacp's Avatar
In a nutshell, yes it would appear you have all that is needed. As Woo5ie said, it is a good idea to protect from metal to metal contact by covering the jack's contact points.
Old Aug 3, 2018 | 07:24 AM
Ranchero50's Avatar
I put my jack stands further out. In the rear under the three bolts for the steel rear substructure inboard of 'A' and in the front usually on the rear lower A arm at the bushing. I've seen too many weird things happen when the stands are too close together.
The most important thing is once it's up in the air to give it a good push to make sure it'll stay there while doing work under it.
Old Aug 3, 2018 | 07:25 AM
I have a similar lightweight aluminium trolley jack:
There isn't sufficient clearance to use one of those rubber pads so I use a thin block of wood.
Old Aug 3, 2018 | 08:13 AM
wrair's Avatar
My jack is a little smaller, so it fits, but didn't come with rubber protection. So I got a few hockey pucks (hard rubber) for the stands and jack. About $1.50 each. For me,wood tends to split.
~wrair
Old Aug 3, 2018 | 08:51 AM
kj07xk's Avatar
Yup, for those simple tasks like changing a tire, I use a low profile jack, like the one pictured, and a hockey puck with a groove in it (pretty sure I got it on amazon). Had a 2 ton Harbor Freight jack that started ‘creaking’ after about a year, so pitched it and got a better 3 ton jack. My older Sears jack was too tall to fit under these low profile cars, so it doesn’t see much action these days.
I use the ‘A’ points for jacking, making sure all plastic bits are cleared.
Old Aug 3, 2018 | 09:53 AM
Ter11's Avatar
Good point... low profile jack!
The one I use was initially bought for my Landrover Defender - there “low” was not so much of an issue, on the opposite! I will need to check if I will be able to use my current trolley jack on the XK!
BR
ter
Old Aug 3, 2018 | 04:59 PM
Queen and Country's Avatar
Thank you. Been looking for that answer for years, and have had to resort to the exact same and wondered if there was a better way. And you would know if there was one.
Would you point out on the diagram your jack points.
Additionally, how about when needing to jack up and place a jack stand.
Old Aug 3, 2018 | 06:54 PM
kj07xk's Avatar
Went back in my Amazon purchase history, and found the jack I bought:
Amazon Amazon
And the slotted hockey pucks:
Amazon Amazon
Although it looks like they changed the pucks, the current ones are light colored, mine are black.
Old Aug 4, 2018 | 07:28 AM
Ter11's Avatar
cross link to similar thread here that I just found: https://www.jaguarforums.com/forum/x...-187308/page2/
Old Aug 5, 2018 | 07:33 AM
Ter11's Avatar
Checked today under my XK. My trolley lift has minimal hight 14.xx cm. This is just enough to get under the XK. But without any rubber cushion.
I guess I will also use a cloth as cushion.
Btw. Even if clearance was enough I could not use the depicted rubber cushion placing the car‘s longitudinal steel pressing (don’t know exact words in English!) in the cushion’s V-shaped slot. Why? Because just next to the jacking point the plastic sill starts, and I guess you better don’t touch this when lifting the car.
Br
ter
Old Aug 5, 2018 | 08:49 AM
Ranchero50's Avatar
Dude, couple wooden planks are your friend. Two 2 x 12" boards nailed together are good for 3" of extra clearance.
Old Aug 5, 2018 | 09:51 AM
Sean W's Avatar
^^^^What he Said plus this with a low profile Jack. It's what I used prior to getting a lift and it worked great.
Old Aug 5, 2018 | 10:20 AM
Ter11's Avatar
cool! I used this plank method last time 20y ago with my first car😉. Good point. Will see to get some planks at hand or - in the best case - those planks used for my first car can still be found in my parents house basement.
Br
ter
Old Aug 8, 2018 | 09:08 PM
Mufc's Avatar
I use Rennstands by Safe Jack. Solves many problems.
Old Oct 15, 2018 | 12:19 AM
MarkyUK's Avatar
Looked up this thread and thought I'd update on repair and tyre shops lifts in relation to my XK Dynamic R
Yes they've all had low profile jacks suitable for change wheels, however three have said my car is too low and wide to put up safely on their lifts...the dynamic body kit seems to be the issue.
Alignment wasn't a problem as took my car to a Merc specialist that does lots of work in the McLaren community so they lifted it on a drive on ramp.
The problem with the others is that they have fold-out/in arms and there's insufficient clearance around the body kit, below are pictures of my car lifted an another one of the car itself in sideview. Gap between the side skirts and the ground is a mere 5.25"/13.25mm
I appreciate mine has lowered suspension but I'd appreciate knowing the sill/ground clearance of a non-lowered/bodykit XKR?
Also, as it's so low, many shops have a real problem getting down their and finding the jacking points
Thanks for the jacking point locations Ter, I'll print that off and keep in my glovebox for future use
Old Oct 16, 2018 | 12:59 AM
u102768's Avatar
Around 15cm from the ground to the bottom face of the sill and 14cm to the bottom of the lowest bolt.
Old Oct 16, 2018 | 01:08 AM
peterv8's Avatar
I have a scissor lift and find it annoying to have to go down on my knee's to find the lifting points and to put a rubber puck in place.
Would this be okay on our cars and has someone used/uses them?
Old Oct 16, 2018 | 07:17 AM
jagtoes's Avatar
If you are distorting the plastic rocker panels then I would suspect that at some point you will crack them. These type of jacks are great but you should consider building a small jig out of wood with the jack points located on it .
