Scratched glove box door
Old Feb 20, 2014 | 08:33 AM
bocatrip's Avatar
Default Scratched glove box door
My girlfriend managed to scratch the black leather on the glove box door on my either wise flawless interior. I guess it was either her ring or handbag. These things happen but of course it bothers me. The leather is not torn, but you can see a thin line (2 or 3 inches) that has the leather somewhat bunched up. I put a fair amount of lexol on it and the entire door knowing it wouldn't really do much. A new door is $650 without the install....wow! Any suggestions as to get the door cheaper or should I just take a Xanax! Thanks all.
Old Feb 20, 2014 | 08:38 AM
ndy.boyd's Avatar
If the scatch isn't too deep, baby oil or olive oil might revive it. Rub either in a circular motion around the scratch and let it sit for a few hours. It may revive the leather. I've tried this in the past on leather furniture and it is effective.
Old Feb 20, 2014 | 08:44 AM
ndy.boyd's Avatar
I forgot to mention, you should use a q-tip to dab the baby/olive oil into the scratch before using a cloth to swirl it. Also, after it dries and you give the surface area a wipe with a damp cloth, if the scratch is still visable, try using a steamer on the area. (not too close) This may bring out the natural oils in the leather to help "heal" the damage.
If none of this works, the Xanax route may be the next step.
Best of luck.
Old Feb 20, 2014 | 08:45 AM
bocatrip's Avatar
Thanks ndy.boyd. From your mouth to God's ears! If it works, I'm sending you a case of Johnson's Baby Oil!
Old Feb 20, 2014 | 08:46 AM
MaximA's Avatar
Did you also check some of the online resources for the door. terry jag, SNG Barratt? Their prices are half what your local dealer will charge you.
Old Feb 20, 2014 | 09:32 AM
bocatrip's Avatar
Best of luck.
I've used some olive oil on a q-tip. Could this stain the area and make it worse or will it come off with the damp cloth and some lexol?
Old Feb 20, 2014 | 09:51 AM
ndy.boyd's Avatar
No, it should not stain the leather. What it does is it softens the edges of the scratch so that it more easily blends back into or close to its original form. What color is your leather? If its a very light color, you may be given comfort if you try it on an inconspicuous location first, but I've done this procedure on light tan leather and it had no discoloration effect. Just make sure that you spread it about after the q-tip application.
Old Feb 20, 2014 | 09:57 AM
bocatrip's Avatar
Warm Charcoal. What should I use to remove it? Lexol cleaner,lexol, or just a moist cloth?
Old Feb 20, 2014 | 10:04 AM
ndy.boyd's Avatar
Just a lightly dampened cloth. Did you take a pic of the scratch. I'd like to see it, if possible. Once the olive oil soaks in, take a marble, if you have one and roll it gently, back and forth across the scratch to bring the edges back together. If you don't have a marble, use the back of a soup spoon, but don't press very hard.
Old Feb 20, 2014 | 10:17 AM
JustNiz's Avatar
Its simple!
Just get Jag to send you a new replacement and send your girlfriend the bill. :-)
Old Feb 20, 2014 | 10:18 AM
bocatrip's Avatar
You are a regular surgeon!!! Great advice. I was getting myself crazy (which is not hard to do) and went out to wipe the olive oil off with a moist cloth. It came right off. It is not that noticeable unless you look for it. Your advice with the marble or a soup spoon sounds good, but sometimes "less is more" is the best way to go. I think I'll leave it alone for the time being other than doing another q-tip olive oil treatment. My girlfriend will be taking her rings off and leaving her handbag in the trunk from now on.
Old Feb 20, 2014 | 10:21 AM
bocatrip's Avatar
Originally Posted by JustNiz
Its simple!
Hah. All her car bills regardless of what they are always seem to come to me.
Old Feb 20, 2014 | 10:26 AM
ndy.boyd's Avatar
Glad its looking better. Otherwise, your next thread could have been:
"Does anyone know how to remove a pick-ax from a girlfriend's forehead"?
Old Feb 20, 2014 | 01:32 PM
Mountaincat's Avatar
Hopefully the wife hasn't noticed this!
Old Feb 20, 2014 | 05:02 PM
SoCal Babe's Avatar
Default Pick axe?
How to remove it? WITH A SHOTGUN. aim just below where itis inthe skull. Advice from my boyfriend!!!
BadKat174
May 26, 2023 12:29 AM
Jandreu
Jun 30, 2022 03:10 PM
XJsc-guy
Nov 23, 2015 01:56 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
tvholden
Sep 12, 2015 11:13 AM
