Seat belt tensioner behaviour
Old Oct 12, 2018 | 08:50 PM
RobB's Avatar
Default Seat belt tensioner behaviour
Hi,
When moving around in the car, the seat belt becomes slightly slack and it will not retract sufficiently. However, when I disengage the seat belt lock, it tensions immediately. This is a simple, but annoying workaround!
I've lubricated the reel, but this has made little difference. Any suggestions on cause or solution please?
Old Oct 12, 2018 | 09:51 PM
pwpacp's Avatar
Any seat belt that will not tension correctly needs to be replaced right away. Several are offered on eBay, here in the US, as well as some tensioner repair services. Hopefully Oz has similar listings.
Old Oct 13, 2018 | 01:21 AM
peterv8's Avatar
Could there be some kind of brake mechanism on the real? Have you had the the panel off so you can access it to give it a good clean and lubrication?
Old Oct 13, 2018 | 09:07 AM
IanXF's Avatar
Dirt build up on the seatbelt itself could cause slow retracting.ive used a good cleaner on a wet towel to clean them.you would be surprised how dirty they get
Old Oct 14, 2018 | 06:37 AM
RobB's Avatar
Thank you, I hadn't thought of that.
My confusion is that the seat belt retracts perfectly when released, but doesn't tighten back up properly when engage into the lock. This suggests that there is nothing fundamentally wrong with the retracting mechanism, but that it is not always correct on the level of tension to set?
Old Oct 14, 2018 | 12:47 PM
hafren's Avatar
Apply some silicone spray to the openings the belt passes through i.e. upper D ring, top of seat etc. It may be you have friction in locations the belt moves over when across your body but lies in another orientation when released.
lev
Jan 28, 2020 08:55 AM
Roadhogg
Sep 17, 2012 12:04 AM
Oubadah
Oct 9, 2010 12:16 PM
2000blackxkr
Sep 13, 2009 10:28 PM
xjsix
Oct 30, 2008 10:35 AM
