Service indicator
Old Mar 10, 2020 | 01:27 AM
SEAICE's Avatar
Default Service indicator
Recently getting Service indicator warning on start-up. goes away in a few seconds. I bought an icarsoft LR v.2, but it does not show what services are required. Admittedly, haven't spent much time with the icarsoft. Instructions are terrible! (My Carly for BMW was much more handy and intuitive). Is there a way to know what service is required from the vehicle's menu? I'm thinking oil, though not because of mileage, but because of time.
Old Mar 10, 2020 | 03:15 AM
The Service Indicator isn't that advanced. It is a simple countdown against miles or time elapsed since the last reset. The reset procedure doesn't require an SDD session:
Normally reset at Service, an intermittent and unexpected warning message display can occur after running diagnostics - especially with a code clear.
Old Mar 10, 2020 | 11:27 AM
Cee Jay's Avatar
Those above button pushes are quite finicky, and need to be done in a heartbeat rhythm to work. A steady beat and practice a couple times before attempting. Seriously.
Old Mar 12, 2020 | 06:56 PM
DGL's Avatar
DGL
When you do the reset procedure do not have the trip ometer displayed on the instrument cluster--you will not get the "service mode reset" confirmed messaged.
Old Mar 13, 2020 | 09:43 AM
Sean W's Avatar
Yep and what SDD doesn't mention is you need to lift your right cheek and fart to the 1812 overture while resetting - or if outside the US, left cheek.
guppydriver
XE ( X760 )
16
Aug 17, 2019 10:59 AM
asieradz
XF (X260)
Apr 23, 2017 03:07 AM
dannygjatt
Aug 8, 2011 10:37 AM
