Service indicator reset.
Old Oct 22, 2022 | 08:32 PM
Jaggyx's Avatar
I had an issue with this until I disconnected Bluetooth, so make sure it's disconnected people!
Old Jan 18, 2023 | 10:37 AM
htrdlncn's Avatar
Every time I do this I imagine some Jaguar engineer at home laughing his *** off
at what he makes us owners do to reset the service light..
On my other car, you hit menu on dash,scroll down to reset, push ok.
Only thing Jaguar left out was to get out of car and dance a Jig to the Jaguar gods..
Frank G
Originally Posted by Executive
This is the procedure for the XF. Should work on the XK.
1. Press and hold the rear fog lamp switch (before the ignition is on).
2. Press the start button without applying the foot brake (do not start the engine)
3. Release the rear fog lamp switch (1sec)
4. Press and hold the trip computer cycle switch (within 1sec).
5. Press and hold the rear fog lamp switch. (within 1sec)
6. Continue to hold the trip computer and rear fog lamp switches.
7. The message center should display "resetting service mode" and then "service mode reset"
8. Release the trip computer and the fog lamp switches and turn the ignition off.
Old Nov 18, 2023 | 05:05 AM
Damirich's Avatar
It worked for me (XK 5.0 2011) only after switching to the radio, switching of the bluetooth connections and portable devices. Thank you for the instruction!
Old Jul 30, 2024 | 10:52 PM
lear60man's Avatar
Originally Posted by BlueXKR-S
I've had the same issue today, Must have tried 20-30 times with the same result. I got stuck in "Resetting Service Mode" message and then nothing else. Then, I did 2 things
1. Disabled Bluetooth connection to my phone
2. Switched display from showing trip mileage to current speed
After that, it worked on the first try. My guess is that #2 two made a difference. Computer was fooled into resetting the trip counter instead if resetting the service light.
Dude!!!!! Well done. Ive reset my service reminder many times between our 3 JLR products over the years. But tonight I was stumped thinking I got the procedure wrong. Nope....just had the phone connecting via bluetooth in the cabin.
Old Jan 11, 2026 | 02:36 AM
alanroberts50's Avatar
Default Another twist
so having successfully got as far as the resetting service light mode and getting stuck there I did the 2 things mentioned above! Imagine my frustration as now I can’t get past the original service Required msg! The original procedure doesn’t do anything now. Any helpful suggestions?
Old Jan 11, 2026 | 04:02 AM
paulsjag's Avatar
Confession time, I had a Mr 12v installed in March, I never managed to do it and the service warning was on till December when it was actually serviced. It reminds me of wiper service position on my other Jag, still never managed it.
Old Jan 12, 2026 | 08:00 AM
Default Update success!
someone had mentioned earlier that it was not necessary to wait 12 hrs to retry but because I got frustrated and left it overnight before taking it back to the shop I thought I would give it one last try and total success first try! I did switch off my phone Bluetooth and had the the audio set to radio same as the night before.
Old Mar 4, 2026 | 03:43 AM
  #28
NickX150's Avatar
Originally Posted by HouTexJag
This worked great! I just took my XKR in for service and they didn't reset the service reminder so this kept me from having to take it back. The first couple of attempts didn't work because I wasn't doing it fast enough, but finally got it right.
I have an early X150 (2006) which doesn't have the need to reset? Unless I'm missing the point?
With kind regards
Nick
Old Mar 4, 2026 | 06:49 AM
kj07xk's Avatar
With kind regards
Nick
Correct. It’s a 5.0L car thing.
Old Mar 6, 2026 | 03:40 AM
  #30
USMMA90's Avatar
Any other suggestions if you get stuck in “resetting service mode”
Old Mar 6, 2026 | 09:18 AM
  #31
Cee Jay's Avatar
I've had my car twelve years, never had to try more than four times to get the thing reset. Phone connected or not, OBD2 plugged in or not. I found an even tempo was most important.
Old Mar 6, 2026 | 12:34 PM
  #32
XKDreams's Avatar
Would it have been too difficult to put the reset in the nav screen?
Old Mar 6, 2026 | 12:40 PM
  #33
Cee Jay's Avatar
My F250 has it displayed on the dash... "Hold 'OK' for five seconds to reset service reminder".
Old Mar 9, 2026 | 03:55 PM
  #34
XKDreams's Avatar
I’m not skilled enough to get through the reset sequence in the right order and time to reset it in my ‘15 XKR.
Old Mar 11, 2026 | 05:01 PM
  #35
HealeyJag's Avatar
Talking understand...
Understand..
When resetting my wife's epace was simpler..
Open hood..
lower passenger window 2,5 inches..
scream loudly....
Say a prayer
Old Mar 14, 2026 | 09:35 PM
  #36
Tracee's Avatar
I've found that printing-out the reset procedure and taping it to the steering-wheel (or wherever in view) is helpful in following the steps.
Old May 18, 2026 | 09:57 AM
  #37
x9nov's Avatar
I had to change my battery recently on my XKR 5 litre, so the service indicator came back on. I struggled at first to even get as far as getting the reset message. This is what I found by reading the various comments above, I also have the Mr12Volt fitted Car play, I managed to get the complete reset done by simply turning the audio off (just pressed the volume knob to off) and then made sure the middle display was showing mileage left with the fuel in the tank (if you know what I mean). Once I did this first the reset procedure worked straight away, I hope this helps someone.
wardwe64
Aug 6, 2018 01:25 PM
raulchamy
XF (X260)
Jan 17, 2018 06:19 PM
TMack
Sep 9, 2014 04:22 PM
10 XF Premium
Apr 9, 2013 06:44 PM
licknstick
Oct 6, 2012 12:41 PM
