Service Intervals
Old May 15, 2019 | 10:48 AM
yidal8's Avatar
Default Service Intervals
Going to check a 1-owner 2015 XKR for sale. The pdf Owners manual I have (2012) does not have the recommended service table for some reason.
Any quick links?
Old May 15, 2019 | 10:52 AM
Cee Jay's Avatar
Intervals are listed in the "Service Portfolio" and not the manual.
I'll see if I can find 'em...
Old May 15, 2019 | 10:59 AM
Cee Jay's Avatar
You're welcome.
Heck, I'll keep a copy of this for myself.
Old May 15, 2019 | 11:21 AM
Stuart S's Avatar
Default Important oil change information
5.0L engine owners are asking for trouble if you wait to change your oil every 15,000 miles or 1 year, whichever comes first. I wouldn't go past 7,500 miles since oil is cheaper than replacing the chain tensioner guides. And make sure that you use only the required spec STJLR 51.5122 0W-20 oil to get proper oil pressure at cold startup. For details, see this thread:
https://www.jaguarforums.com/forum/x...t-done-214277/
Old May 15, 2019 | 12:11 PM
tractioninc's Avatar
The ZF transmissions specialist near me is emphatic that the transmission fluid and filter in our cars should be changed every 50-60K miles (80-100K km). The water pump will likely need to be changed at a similar interval.
Old May 15, 2019 | 12:31 PM
Cee Jay's Avatar
That.
I changed my Trans Fluid at about 64k, was nasty and stinky.
Old May 15, 2019 | 12:50 PM
yidal8's Avatar
"You're welcome.
Heck, I'll keep a copy of this for myself."
Perfect, heading to check it out tomorrow.
shemp's Avatar
Where is the fuel filter on the XK?
Old May 15, 2019 | 12:59 PM
Sean W's Avatar
On the 5.0, it's in the tank attached to the mounting flange. It's a non serviceable part and can only be replaced by replacing the mounting flange.
Old May 15, 2019 | 01:03 PM
Sean W's Avatar
On the 4.2's, both N/A and SC, it's on the drivers side in front of the fuel tank.
Old Apr 2, 2024 | 02:52 PM
Lothar52's Avatar
Originally Posted by Cee Jay
That.
it’s nasty and stinky when new…. Eeeee gads… stinks to high Heaven!!
Old Apr 2, 2024 | 02:53 PM
Lothar52's Avatar
oil is cheap… change your own and have fun doing it!! I’m doing mine every 3000 miles with 0w20 amsoil signature series… man the engine is so smooth!!
multiplecats
Jan 8, 2015 04:41 AM
ashbypa
Sep 29, 2014 04:53 PM
jagxkrtoofast
May 14, 2010 09:19 AM
MTW
Mar 18, 2010 09:57 AM
390HPTypeR
Feb 21, 2010 06:03 PM
