Side Marker Removal
Old Aug 22, 2011 | 09:43 AM
Mike V's Avatar
Default Side Marker Removal
Anyone know the best way to pop out the side marker/indicator housing?
The manual says push firmly to the back but every time I try it feels and sounds like it's about to break.
Old Aug 22, 2011 | 12:38 PM
GhostriderXKR08's Avatar
Hey Mike......not sure if this pic will help as the hole is actually where the bulb socket sits as the housing is over that. I removed the louvers before but forgot how the side marker housing detaches. I have the housing somewhere in the storage but I tried to look for it but couldn't find it.
Maybe use a small flathead screwdriver (of course use a cloth in between) and gently pry it towards the rear of the vehicle (according to the manual). Just a thought.
BTW.....or get the '10 louvers for a cleaner look.
Old Aug 22, 2011 | 11:52 PM
Mike V's Avatar
Default Thank you
Thanks Ghostrider... got it off with just a small chip on the housing (oops) luckily it's on the part in your pick so the housing hides it.
I did this to test if I swapped side marker bulbs would the "indicator lamp failure" jump to the other side as well.... It didn't
I'm going to test the ground wires next and possibly re-wire the tail lamp ground, this worked for some BMW owners.
Any luck with your brake lamp?
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
02jagstype
23
Oct 23, 2022 07:03 PM
avern1
Sep 8, 2015 06:25 PM
Dallas XK8
Sep 3, 2015 12:17 PM
