Smart keys added
Old Apr 4, 2025 | 06:14 AM
kj07xk's Avatar
Originally Posted by alanroberts50
Not sure why but I keep my emergency key blade separately on my key ring. Anyone have opinions to share as I’m not sure if this is a good idea or not?
Also if the emergency key is used does it automatically set off the alarm and then you have to dock, or can you get home with the blade only?
The key blade will only open the doors. You still need the fob to start the car (docked, if the fob isn’t recognized while undocked). Don’t think the key blade will cause an alarm.
Old Apr 4, 2025 | 07:10 AM
powelld91's Avatar
Originally Posted by Stuart S
@powelld91
I suggest that you keep a spare factory sealed CR2032 battery in your glove box. Be sure to check the date to make sure it's fresh.
You can easily swap the board with the electronics from your beat up old OEM case to this new OEM case on eBay. You'll have to use your old chrome retaining rings and emergency key:
eBayhttps://www.ebay.com/itm/387326194469?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=v7lranaftyq&sssrc=4429486&ssuid=XJ8PXArNRB K&var=&widget_ver=artemis&media=MORE
If your chrome rings are in bad shape, just by a cheap clone case and use the chrome retaining rings.
Interesting! Do you know whether these have the leaper logo on the back? They only have one picture and that is of the front. If so, I will probably get these and move the electronics from my knock-offs into OE-looking cases.
The chrome ring is missing altogether, but the real issue is that the plastic tab that holds the key in is also missing.
Old Apr 4, 2025 | 07:39 AM
Stuart S's Avatar
Dan,
All I know is what I previously explained in my Post #19, above.
That eBay seller says it's a genuine Jaguar shell. It's only $15.90 including shipping, and it's covered by eBay's guarantee. Buy it. You have nothing to lose. Just be careful swapping the electronics board. Or pay a locksmith to do it.
Also buy a cheap Chinese clone for the chrome retaining rings and hope they fit. Most likely they will.
Good luck!
Stuart
Old Apr 4, 2025 | 08:08 AM
powelld91's Avatar
Dan,
Good luck!
Stuart
I went ahead and ordered a couple. We'll see how it goes.
You could probably even put your electronics into a new-style key fob if you were so inclined.
Old Apr 4, 2025 | 10:37 AM
hafren's Avatar
Originally Posted by powelld91
I would have to say I did not since I don't know what a docking station is in this context. They lock and unlock the doors, and I can start the car. For those purposes, they do work.
I will have to try that docking thing. I can't imagine why the fob would fail to unlock the car but be recognized in the dock.
Not sure if you've tried your keys in the docking station yet (start control Unit) but its possible to clone keys (cheap & dirty programming) that do not program the active part of the security system. This can leave you stranded unable to start your car and its not just a scenario of a low fob battery. That's why I suggested you check and have some recourse if they are not fully programmed. Read the attached to learn about passive and active starting & security.
File Type: pdf
Old Apr 4, 2025 | 10:43 AM
Stuart S's Avatar
Nope, it won't fit in the dock.
Old Apr 4, 2025 | 10:53 AM
hafren's Avatar
Also, the cheap Chinese clones on eBay and AliExpress are not exactly the same size as the OEM Smartkey shell (with the Leaper logo on the back) and might not fit properly in the dock. Read this thread from 2020:
Smartkey Won't Dock
I think the jury is out on the supposition that they are "not exactly the same size as the OEM Smartkey shell (with the Leaper logo on the back) and might not fit properly in the dock" That post shows multiple instances how contributors did not know how to use the start control unit (dock) and their observed failures where normal functioning. Jaguar specifically cautions:
CAUTION:
Do not use force to remove the Jaguar Smart-
Key as this may cause damage to the start control
unit.
Do not attempt to hold an invalid key in the
start control unit in an attempt to prevent it
from being ejected.
I would agree that if buying non OEM keys/shells have recourse to return them if they wont program or chrome side pieces wont fit.
Old Apr 4, 2025 | 01:11 PM
  #28
powelld91's Avatar
How would you become stranded? If I had to use my key to enter because the fob was dead, I see that. If I had a fresh battery in the glove compartment, could I then use the fob to start the car?
Old Apr 4, 2025 | 03:25 PM
Stuart S's Avatar
Let's hope that you never have to find out.
Old Apr 4, 2025 | 05:01 PM
  #30
hafren's Avatar
Your car like mine is 15 years old and is heavily controlled by electronic modules. If you read the pdf you'll understand how passive communication is different to active and importantly starting is different to ulocking. See pdf page 20 and you'll see which modules allow passive start vs active start. Modules are generally reliable but read the forum and you'll find instances of module problems and Jaguar have importantly given owners alternate means of starting the car, not by accident.
The information provided is intended to help & educate. Its your car so you choose how to understand and operate it.
Old Apr 5, 2025 | 08:43 PM
  #31
Tracee's Avatar
[QUOTE=Stuart S;2835223]
"...programming the X150 Smart key to work remotely and programming it to work with the dock are two different procedures."
Programming it to work in the dock is an extra step in the SDD procedure, as you said. After you've done the programming, SDD wants you to do the next step, "validate key(s)". After which point you're done.
I had success cloning (2) extra keys using SDD installed on a laptop I bought from an Ebayer in the U/K. Figured it was cheaper than paying a dealer, and I have the SDD and computer to do other tasks on the car.
It is indeed a breathtaking procedure; follow on-screen instructions to the letter and you'll succeed.
The " blanks" don't have the logo / leaper on the back - meh, fob lives in a protective leather covering anyway, bought from Ebay.
Old Apr 17, 2025 | 08:51 AM
  #32
powelld91's Avatar
[QUOTE=Tracee;2835820]
I am expecting my SDD set up today, also purchased from an eBayer in the UK. Is key programming something that is just obvious when you fire up SDD or is there a significant learning curve? Did you write custom code or is it a function of SDD?
I posted yesterday that my only OE fob stopped working for starting the car after I changed the battery. Works to lock/unlock or release the trunk, but not for starting the car. Hopefully I can get it working again once I get SDD.
Old Apr 17, 2025 | 11:40 AM
  #33
Cee Jay's Avatar
[QUOTE=powelld91;2838445]
Oh, there's a learning curve for sure. It's not an obvious system by any means. One thing though, FOLLOW WHAT IT SAYS TO DO once you start something; tick this, push that, off, on, all of it or something may go horribly bad very quickly.
Old Apr 18, 2025 | 11:24 PM
  #34
Tracee's Avatar
Been about a year since I used SDD to make copies of fob, but as I recall, once you get into SDD,, you click on "Security" and scroll down to "Add extra keys", and follow the prompts. Also, my unit came with the advisory to reload SDD every (90) days. Yours may or may not have that instruction; guessing it was part of a licensing scheme that the dealer had to renew.
Old May 5, 2025 | 03:13 PM
  #35
powelld91's Avatar
When you ran this SDD routine, did the new key work in the dock as well or is that a separate routine?
Old May 5, 2025 | 04:04 PM
  #36
Tracee's Avatar
From my extensive reading on the SDD / key procedure, I learned that, after you complete the "add additional keys" procedure, you go to another step, "Validate (verify?) keys", just a few steps down on the
"Security" section. This would complete the entire operation and assure the fob will work in its slot, when needed.
Old May 5, 2025 | 04:09 PM
  #37
powelld91's Avatar
Cool. I have one OE key I received with the car that will verify but for some reason, the car decided it can't remote lock/unlock nor button start the car any longer. It will still work in the dock, though. I had an auto locksmith program a key also, that worked for remote lock/unlock and button starting, but not in the dock. One day, the car decided that key should no longer work, either. I am still trying to figure out how to stop the car from forgetting keys.
Old Feb 4, 2026 | 09:02 AM
  #38
bck's Avatar
bck
Just bought a 2011 XK that came with only one fob and live in Clear Lake. Could you tell me where you had your keys cut and how the new fobs and SDD programming went? I'm on the same path it sounds like.
Old Feb 4, 2026 | 10:04 AM
  #39
Jaguar!2's Avatar
I actually both my fobs 2 new ones complete off ebay and can confirm they work. I did the coding myself using JLR SDD. I had metal keys so did not need them cut I think a decent key place can cut them if you have an original key.
Old Feb 4, 2026 | 10:12 AM
  #40
HealeyJag's Avatar
That's great!!
Seems to be the exception rather than the rule..
Glad it worked out..
for me it didn't after 2 sets of keys...
went to dealer...
