Squeak from rear..
Old May 1, 2019 | 12:06 PM
S-Typer's Avatar
Default Squeak from rear..
Hi Guys,
I had a small incident on Friday and hit standing water. The left rear tire hit a small curb and popped. I was able to get a used tire to hold me over until a new one to match my other arrives.
The tire was installed and I was able to drive the car back to my garage (5 miles) and it seemed fine. Now I moved the car to go to the store and I hear a squeak that only happens when the car is moving (forward or backwards). It doesn't seem like suspension or anything as it happens even if I move a inch or two. Could this be the mismatched tires on rear causing the diff to squeak? The tires are different brands, but the same tire size. I wont drive the car anymore until I get matching tires on it...just curious if I have bigger problems. The car made no noise when I drove it back from tire shop.. Now its a squeak, squeak, squeak..it sounds like its coming from the rear. I lifted the car and the tire moves freely back and fourth and there's no noise.
Thanks!
Joe
Old May 1, 2019 | 12:25 PM
Stuart S's Avatar
Impact with a curb that causes a rear tire blowout could cause all sorts of other damage to the rear axle components including, but not limited to, a bent wheel, wheel bearings, axle shaft, differential gears, mounting brackets and bushings. I recommend that you call your insurance company and ask them if your collision policy covers damage caused by your accident with the curb, subject to your deductible. I think it should be, but check to be sure. I also recommend that you pay your Jaguar dealer to do an inspection for rear axle and suspension damage. The blown tire could be the tip of the iceberg.
Old May 1, 2019 | 02:34 PM
S-Typer's Avatar
Thanks for the advice. I was hesitant to get insurance involved as I didn't want to damage the Carfax / insurance rates.. After thinking about it. I called my dealer and got a claim going. It just got loaded on a flat bed. It was noise I never heard before and I started thinking about all the stuff that could have gone wrong back there. My dealer is great and he will make sure he looks at everything. I'll keep you guys posted!
Thanks again,
Joe
Whirlinturbin
Jan 10, 2016 08:20 PM
badplan1
Jul 22, 2010 06:35 AM
churmsk
Jun 24, 2010 11:45 PM
datekho
Sep 9, 2009 07:03 AM
McJaguar
Jan 28, 2009 11:08 AM
