Squeaky seat
Old Apr 16, 2026 | 01:56 PM
Ter11's Avatar
Default Squeaky seat
Hi all
My XKs driver seat squeakes when I enter the car first thing in the morning and sit into the seat.
Anybody had this and has a suggestion how to get rid of this?
Best regards,
ter
Old Apr 16, 2026 | 03:41 PM
kj07xk's Avatar
Originally Posted by Ter11
Hi all
Best regards,
ter
You might need to narrow it down a bit.
a. Is it the seat bottom, or seat back?
b. Does it squeak the second time you sit that day?
c. After it squeaks, if you get out immediately and then re-sit, does it squeak?
d. Before you sit, can you reproduce it by pressing the seat cushion with your hand?
Old Apr 16, 2026 | 06:23 PM
guy's Avatar
guy
too much information.
Old Apr 17, 2026 | 12:46 AM
Ter11's Avatar
Thanks for the quick response. I will test this asap and get back to you with a more in depth description. Much appreciated!! Ter
Old Apr 19, 2026 | 03:33 AM
Ter11's Avatar
UPDATE:
a. Seatbottom. Area where one sits with bottom cheeks.
b. It usually sqeaks only when I sit in first time for a drive. If I drive again the same day some hours later, it can happen again.
c. Yes. Again.
d. Yes. Tried today, see video below..
video link:
Ps. These are original white/black seats of the 2011 E50 Anniversary Edition (more).
Old Apr 19, 2026 | 08:41 AM
wymjym's Avatar
The seat leather is held in place by metal hog rings. They attach to a metal-rod frame embedded in a foam form. This metal frame work is a two piece affair where one section fits into the other.
The sound I hear is similar to what I have heard when one piece of this metal rod slides on another piece while under pressure. ( shouldn't happen but could if one section isn't aligned properly)
The seat probably needs to be partially disassembled to determine and repair the problem.
WJ
rjwood22
Aug 2, 2025 08:46 AM
Glyn Richards
May 8, 2024 09:14 AM
claytoncramer
Mar 11, 2023 08:47 PM
iramphal
Dec 19, 2022 05:56 PM
EJ Garity
Aug 17, 2015 12:09 AM
