squealing brakes... argghh...
Old May 25, 2020 | 01:27 PM
Ian Rattray's Avatar
Default squealing brakes... argghh...
Hi all,
This is a photo of my new baby, Genevieve... 2008, 98,000 miles, almost perfect... BUT, her brakes squeal!!?
Over the past couple of weekends, I have whipped all wheels off and greased all the appropriate connection points @ the calipers and pads, but, although it is better than it was, I still have the squeal.
The squealing is @ low speed, light brake application, and intermittent, only when coming to a full stop??
Any ideas on what to do next? The pads that are on her are proper Jaguar pads, with tons of meat left on them (well over 1/2")... b ut I am a bit stuck now as I think I have done the obvious stuff??? (maybe?)
Cheers in advance for any advice y'all might have.
Best regards, Ian in Atlanta (although originally Dundee, Scotland)
my new baby... 2008, 98000 miles, not a mark on her... (hers names Genevieve)...
Old May 25, 2020 | 02:37 PM
MarkyUK's Avatar
If pads are OK what state are the discs in Ian?
Old May 25, 2020 | 03:12 PM
they are in great shape, not awarded and no ridges...
Old May 25, 2020 | 03:13 PM
sorry, not warped... not awarded!! LOL...
Old May 25, 2020 | 03:32 PM
Cee Jay's Avatar
Your pads and rotors are probably glazed. You can fix it yourself if you have the right tools. Sand down the pads evenly with whatever you have to get to good material, and take a coarse flapper disk to the rotors, both sides, to get a good hatches surface. OR, have the rotors lightly turned by a shop.
Old May 25, 2020 | 03:42 PM
George05's Avatar
hi Ian try mintex anti-squeal , apply liberly to back of pads it will help , look on eBay it's only a couple of dollars for the small tube , The problem is the pads move about , Try taking car for a run on a long quiet road and get up to 50mph then slowly brake down to 5mph , do this 10 times but without stopping , You can also try braking sharply 10 times again without stopping , the discs (rotors can have hot spots on them this can also cause a squeal
Old May 26, 2020 | 09:47 AM
thank you!!! I will give this a try...
Old May 26, 2020 | 11:02 AM
mosesbotbol's Avatar
How about a few hard 70 - 0 full stop braking? That usually clears up many squeaks; especially if the pads are glazed.
Old May 26, 2020 | 11:11 AM
sounds like I need to get grizzly with the brakes!! LOL...
Old May 26, 2020 | 05:04 PM
George05's Avatar
Yeah just seen the others posts good advice , not been a good day for me today . was attacked by some nutter while out on a job trying to steal my tools from the van , MY mistake in leaving it open got a nasty gash on my arm now in the scuffle but managed to hold him to cops attended
Old May 26, 2020 | 05:12 PM
um, not good!!! Hope the guy gets some time...
Old May 26, 2020 | 05:43 PM
George05's Avatar
Thanks we are short staffed i normally in the office only out due to circumstance but yeah london for you . property owner has cctv so should be taken care of but a court case at some point . coppers wanted me to go to hospital but covid city in there , wife upset , just life what can you do i thank judo training as a kid
Old May 26, 2020 | 06:11 PM
George05's Avatar
Stick around, this is without doubt the best jaguar forum on the web, and lots of helpful guys on here eager to give advice.
Old May 26, 2020 | 06:47 PM
OzXFR's Avatar
If deglazing the pads and applying anti-squeal grease doesn't work there are at least two more things you can try.
1. CRC De-Squeak: https://www.ebay.com/itm/CRC-05080-D...AAAOSweP9eTOdW
I used it many years ago (not on a Jag) and it worked great to completely eliminate annoying brake squeal. It's a bit of a PITA to use as you need to thoroughly coat both sides of each rotor then burnish it on by using much the same technique as is used to bed new pads in - lots of hard brakings one after the other (without stopping) until you can smell it burning on and you can see grey smoke. Makes me dizzy/nauseous when I do it though!
2. Replace the brake pads with ceramic pads. All three of my Jags (2010 XFS, 2010 XFR, 2014 F-Type) came with OEM pads and all three made a horrible graunching sound just as the car was coming to a stop, and nothing I did helped until I fitted ceramic brake pads. Hey Presto, the graunch was banished forever.
You will also get two more benefits - much smoother and more progressive braking especially in stop/go traffic, and waaaaay less brake dust than the horribly dusty OEM pads.
Rini
Apr 7, 2016 05:43 PM
Bcrary3
Apr 14, 2015 12:47 PM
concertoed
Sep 11, 2012 08:02 PM
solerunner
Sep 18, 2011 04:55 AM
yaisam
Apr 20, 2010 07:47 PM
