Stomp to Start?
Old Jan 9, 2018 | 08:25 PM
dcmackintosh's Avatar
Default Stomp to Start?
Normally my new-to-me 2013 XKR-S will start with just light pressure on the brake pedal. This afternoon, after sitting in the garage for a week, CTEK connected, the ignition and lights would come on, but it would not attempt to crank. I read on another Jag forum that a heavy press may be required. I pushed hard with both feet and it started normally. After running, it will restart with light pedal pressure. I assume the electronics are looking for a certain amount of hydraulic pressure, not just the brake pedal position switch to be closed. Have others encountered this feature?
Old Jan 9, 2018 | 08:34 PM
Cambo's Avatar
It happens sometimes with mine. There is a bulletin about this but I would have to dig it out.
Old Jan 9, 2018 | 08:43 PM
Christian C's Avatar
It has happened to me twice. Both in the winter when the car has not been started for while.
Old Jan 9, 2018 | 09:15 PM
hafren's Avatar
Yes its looking for brake line pressure >=19.6bar
Old Jan 9, 2018 | 10:06 PM
Stuart S's Avatar
Press and hold the start button in BEFORE you put your foot on the brake pedal. My XKR starts every time with a light tap of the brake pedal.
See my post #2 from this 2011 thread and replies: https://www.jaguarforums.com/forum/x...se-time-57460/
A more complete explanation is in my post #104: https://www.jaguarforums.com/forum/x...y+pumped+brake
Old Jul 19, 2022 | 06:44 AM
Barry Leftwich's Avatar
Mannn quit using that ctek charger if you don't plan on letting the car sit for a month or so.That's probably what did it sending too much electrical currents through the car when it got enough or else the car will start having a mind of its own which sort of sounds like your case lol.But Jaguars are prone to electrical problems and i say avoid any foreign electricity that car itself is not providing if you not gone be letting the car sit for a very long time
Canadacat
Jul 29, 2022 01:17 PM
kiddhan625
Jun 3, 2021 04:55 PM
whedonum
Feb 24, 2020 06:03 AM
mrtalkradio
XJ40 ( XJ81 )
Sep 22, 2011 08:45 PM
