Hooked up icarsoft v 3.0 now car wont start
Old Jul 18, 2022 | 06:45 PM
Canadacat's Avatar
Default Hooked up icarsoft v 3.0 now car wont start
Hopefully its because i had my foot on brake and two much pressure to engage switch. How long does it take to lose pressure so i can try again
Old Jul 18, 2022 | 07:32 PM
u102768's Avatar
When it happened to me a few times on my '07 I just had to press VERY hard on the brake pedal.
Old Jul 18, 2022 | 07:34 PM
Canadacat's Avatar
Gonna let it sit overnight and try in the morning. Hopefully this icarsoft reader hasn't screwed up anything
Old Jul 18, 2022 | 08:42 PM
Stuart S's Avatar
If you inadvertently pump the brake pedal, it will feel high and rock hard. The high pedal makes it difficult to make contact with the starter switch, so you'll have to stand on the brake pedal with both feet when you press the start button..
The simple solution is to press the START button BEFORE you step on the brake pedal.
Note that other manufacturers require that you step on the brake pedal before you press the start button. Jaguar works either way, but I find that my car starts much quicker when I press the start button before stepping on the brake pedal.
My Jaguar service adviser recommended this years ago, notwithstanding the Owner's Handbook to the contrary.
Old Jul 18, 2022 | 08:49 PM
Canadacat's Avatar
Wtf had to do a hard reset, i don't know about this icarsoft scanner. It did reset my driver's seat though, not my passenger though but that might be module related
Old Jul 19, 2022 | 07:42 PM
panthera999's Avatar
Was the Icarsoft JLR-compatible software, and were you using a service function?
Hard reset is a great trick -- saved my *** a couple of times.
Old Jul 19, 2022 | 07:53 PM
Canadacat's Avatar
It was LR JAGUAR VERSION. It did ckean up my driver's seat and went through the motions up diwn , back and forth etc. Did nothing forcmy passenger seat however. Wonder if module is bad, fuses are good.
Old Jul 21, 2022 | 04:24 PM
trkyam's Avatar
I had this exact problem with SDD, unhook your battery for a couple minutes and it will start right up.
This happens every time I hooked up with ODB and read certain modules.
It has something to do with recalibrating the electronic parking brake.
Old Jul 21, 2022 | 06:28 PM
Tracee's Avatar
Roger that for the "hard reset". My IcarSoft bricked my car twice, and a reset (battery connector) brought it back whew. But I've used my Icar a few times before with no problem. I'm thinking that the disconnecting procedure is in question; do you power the tool down before disconnecting, do you power it down before turning ignition off, do you switch ignition off first? The manual says only to end session before disconnecting, which makes sense. Any other IcarSoft folks can clarify?
Old Jul 29, 2022 | 01:17 PM
I agree. Don't just jerk out the dongle when you're done. I close the app, or shut off the car before removing the OBD dongle (or connector), from an abundance of caution about temporarily confusing the ECU. Many scanner manufacturers recommend completing the diagnostic routine, or shutting off the car, before removing. More likely to be a problem is you're doing something active (like clearing codes or a service function) vs. something passive, like a scan and read. And I've done a hard reset to correct a confused non-start ECU or a display Christmas tree while diagnosing.
CB00JAGUAR
May 22, 2023 10:45 PM
dcmackintosh
Jul 19, 2022 06:44 AM
Jagpini
XJ40 ( XJ81 )
Jul 21, 2021 10:13 AM
mlstafford
May 16, 2018 09:36 AM
mrtalkradio
XJ40 ( XJ81 )
Sep 22, 2011 08:45 PM
