Strange fault XKR 4.2 supercharged
Old Mar 12, 2016 | 11:01 AM
Xkrjoe's Avatar
Default Strange fault XKR 4.2 supercharged
Hi all,
I've got fault code PO420, catalytic system efficiency below threshold , it's had two brand new cats and all four lambda sensors done, after 100 to 150 miles the codes come back on, does not seem to affect the performance
Also I have had the backbox deleted and straight pipes to tips put in its place
Thanks in advance
Joe
Old Mar 12, 2016 | 12:13 PM
flyc2c's Avatar
Are they OEM cats?
Old Mar 13, 2016 | 11:14 AM
JagV8's Avatar
Check fuel trims.
Examine the freeze frame data a few times for clues.
Old Mar 13, 2016 | 03:46 PM
flyc2c's Avatar
Good point. May have to disconnect the battery to do an ECU reset.
Old Mar 13, 2016 | 05:53 PM
JagV8's Avatar
The point of that being what?
You'll unset all the OBD monitors. With a car with a known fault they may not set again until it's fixed. Should that occur you may really struggle.
Old Mar 13, 2016 | 05:58 PM
Xkrjoe's Avatar
Oem cats fitted and also will check fuel trims next time I get it out
Very annoying fault after the £££ spent to repair lol
Stuart@VelocityAP
Mar 19, 2023 08:15 AM
Darrenmb
Nov 14, 2020 01:20 PM
dneu
Jan 27, 2020 09:02 AM
XK_SL
Sep 4, 2016 05:20 PM
Doug
Apr 2, 2016 04:56 PM
