Strange gurgling - RESOLVED
Old May 24, 2023 | 04:39 PM
bfarrell's Avatar
Default Strange gurgling - RESOLVED
My 2011 xkr has a strange guggle/ scrape sound which only happens during deceleration and right turns. Its not the brakes or steering beyond that I’m at a loss.
its not getting any worse nor does it effect performance….its just very annoying
any ideas?
thanks in advance
barry
Last edited by GGG; Jun 9, 2023 at 08:33 AM. Reason: Add "RESOLVED" to thread title
Old May 24, 2023 | 09:03 PM
Brewtech's Avatar
Prolly the strangest post Ive ever read. Usually gurgling means everyone is having a good time. Got any video?
Old May 25, 2023 | 01:35 AM
RichardS's Avatar
any ideas?
thanks in advance
barry
Do some short tests on a downhill stretch with the engine switched off in neutral to narrow down the source.
Richard
Old May 25, 2023 | 02:07 AM
steve_k_xk's Avatar
Fuel tank / fuel neck related?? Is it coming from that region.
Old May 25, 2023 | 02:40 AM
Assuming only happens on right turns means you've at least isolated the source to the front of the vehicle? Have you checked the wheelarch liner is properly secured? A wheel rubbing against it makes an odd scraping sound.
Old May 30, 2023 | 08:20 AM
bfarrell's Avatar
Default Gurgling
no its coming from the front of the car only.
never heard such an odd sound in any car
Old Jun 4, 2023 | 06:57 PM
bfarrell's Avatar
Richard
great idea. It turns out that when at speed, i put the car in neutral slow then turn it’s completely quiet. It also only makes this odd sound above 3,300 rpm. Slowing down and or turning right
Old Jun 4, 2023 | 06:59 PM
bfarrell's Avatar
no its definitely in the engine bay. Also it’s been described as a fluttering sound.
so weird….
Old Jun 5, 2023 | 02:59 AM
RichardS's Avatar
If the engine has to be running with the wheel turned it sounds like a problem with the power steering pump although I'm not sure why it makes a noise when slowing down. Can you get it to make the noise by putting the front wheels on some gravel, running the engine up to 3300 revs and then turning the steering wheel from side to side? If the noise appears then it is definitely the PAS pump.
Obviously you need to check that the level in the pump is correct just to rule that out.
Richard
Old Jun 5, 2023 | 05:28 AM
kj07xk's Avatar
Is this something new (when did it start)? Or has it been happening since you bought the car (and how long has that been)?
Old Jun 5, 2023 | 08:00 AM
bfarrell's Avatar
started a few months ago with no new parts added
new find: .in D mode it doesn’t make the sound only during manual mode paddle shifting or S mode slight aggressive driving (revs over 3,5k)
Old Jun 5, 2023 | 08:01 AM
bfarrell's Avatar
Richard
checked pump…no problem there. Actually Thats exactly what i thought ot was so I checked that first.
Old Jun 5, 2023 | 08:02 AM
bfarrell's Avatar
3 months ago it started out of nowhere has t progressed but it’s annoying still.
Old Jun 5, 2023 | 08:48 AM
kj07xk's Avatar
Did you just start regularly using the paddles or S mode a few months ago also? You’re not just hearing the throttle blibs on the downshifts are you? (They do give a nice, what I’d call a ‘burble’.)
Old Jun 6, 2023 | 07:20 AM
bfarrell's Avatar
lol. Yes they do have a nice burble even more with the quicksilver sport exhaust.
i use the paddles regularly…i even changed them to much larger billet ones from VAP .
Old Jun 6, 2023 | 10:48 AM
jons's Avatar
well, if nothing else, the momentum of the vehicle might be causing moving parts to make contact somewhere they shouldn't, or pull on a duct/pipe they shouldn't and expose a crack or seal or something.
Old Jun 8, 2023 | 04:31 PM
bfarrell's Avatar
Its fixed now. Changed air filters cleaned throttle body, new brakes and rotors topped up all fluids ….sound is gone.
thanks for everyones input.
barry
Old Jun 8, 2023 | 07:40 PM
kj07xk's Avatar
barry
Any idea as to what was causing the sound you heard?
Old Jun 8, 2023 | 08:45 PM
steve_k_xk's Avatar
Funny enough a had a car coming in a while ago with misaligned air filter wouldn't say gurgling noise but more like a flutter very odd sound nevertheless
Old Jun 9, 2023 | 06:44 AM
bfarrell's Avatar
Fluttering is applicable….it may have been the air filters as they we’re definitely toast.
barry
Lovemycat88
Sep 28, 2019 03:56 AM
andys-GR
May 10, 2015 04:29 PM
princemarko
Dec 10, 2013 12:36 AM
davidcalgary
May 20, 2013 10:37 AM
topherscott
Jun 28, 2010 04:12 PM
