Supercharger cooling Xkr pump need input on diagnosis
Old Aug 8, 2020 | 06:03 PM
AlexJag's Avatar
Sponsor
Default Supercharger cooling Xkr pump need input on diagnosis
So I have a customer in with a 2007 XKR. I found a bunch of vacuum leaks which fixed fuel trim problems, everything seems to be running good. one thing that is very different from my car is when I squeeze the hose that goes into the supercharger there is almost No movement of water when it squeezed, comparing this to my car if i squeeze the same hose there's definitely water pressure.
Can you guys with an 07-09 xkr check this for me and see how much pressure you have with the stock pump on that hose? Would help to know if his pump is failing or has failed . Thanks
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Aug 8, 2020 | 06:19 PM
guy's Avatar
guy
Air in system? Mine is not rigid, but there is pressure.
Old Aug 8, 2020 | 06:21 PM
AlexJag's Avatar
Sponsor
If you squeeze it harder can you feel the water moving through or just pressure in the hose?
__________________
Old Aug 8, 2020 | 06:30 PM
guy's Avatar
guy
You fill the fluid. While running, escape the air.
Old Aug 8, 2020 | 06:36 PM
guy's Avatar
guy
Did you open the cooler filler plug on the supercharger, squeeze the tube and refill?
Old Aug 9, 2020 | 01:15 PM
AlexJag's Avatar
Sponsor
Yes did all that, hose is pressurized after the car runs but I don't feel the water running through much like on my car , but that maybe because if my uprated Bosch 10 pump
__________________
marke
Jul 31, 2018 05:12 PM
bjrdunn
Mar 14, 2018 11:53 PM
kenatofc
Nov 4, 2013 07:46 AM
cleveland
Dec 15, 2009 07:34 PM
