Power seat issue
The rear part of seat that tilts your back forward and reverse doesn't work. Would a switch be the most likely candidate? Possible loose connection under the seat as anybody experienced this thanks
What jahummer said, a recalibration of the seat is probably what you need. It's a quick ten minute job is SDD, so don't let anyone charge you for more than the minimum labor charge.
okay thanks where can I buy sdd? Might as well have the tool and do it myself if it's not too expensive but I have no clue
Try disconnecting battery, doing a hard reset*, reconnecting and then holding the button of the back tilt for 10 seconds, that's what my Indy did and it worked a treat.
They said it was apparently caused by an FB (NOT FaceBook) passenger placing undue strain on the mechanism causing it to shut down, and no they didn't charge me
* If you don't know what a hard reset is after close to 600 posts there's no hope for you
No probs if you don't want to do a HR and are happy to pay for SDD work instead as the first attempt
My battery was actually changed so had the hard reset and was disconned for over 20 mins and a new type 019 fitted (also done free by my Indy).
Surfer-J
Jul 13, 2009 06:46 PM
