Power seat issue
Old Aug 8, 2020 | 04:44 PM
viper1996's Avatar
Default Power seat issue
The rear part of seat that tilts your back forward and reverse doesn't work. Would a switch be the most likely candidate? Possible loose connection under the seat as anybody experienced this thanks
Old Aug 8, 2020 | 05:11 PM
jahummer's Avatar
Try resetting the car by disconnecting the battery or possibly you need the Jag main dealer to run the seat calibration routine in SDD.
Old Aug 8, 2020 | 05:48 PM
Cee Jay's Avatar
What jahummer said, a recalibration of the seat is probably what you need. It's a quick ten minute job is SDD, so don't let anyone charge you for more than the minimum labor charge.
Old Aug 9, 2020 | 08:05 AM
viper1996's Avatar
Can an expensive Snap-on scanner reset it? Or does it have to be STD
Old Aug 9, 2020 | 09:59 AM
Stuart S's Avatar
STD ??? You can't use that tool!
Old Aug 9, 2020 | 10:47 AM
Cee Jay's Avatar
No Snap-On tool is even remotely close to doing what SDD can do. So, No.
Old Aug 9, 2020 | 11:12 AM
Tracee's Avatar
Any seat motion at all? Try looking at fuse(s) F18, F30 and / or F32 in Central Junction Box.
Old Aug 9, 2020 | 12:40 PM
viper1996's Avatar
yes everything else works it's just a seat back only
Old Aug 9, 2020 | 12:56 PM
George05's Avatar
I had a problem with my seat boalster side bits and the bit that pushes out in the middle , I simply replaced the fuse , sorted
Old Aug 9, 2020 | 01:01 PM
George05's Avatar
Sure it was fuse 30 or 31 I replaced both location is passengers foot well , but might be drivers side on you guys cars as you drive on wrong side of the road
Old Aug 9, 2020 | 02:12 PM
jahummer's Avatar
If it is the seat back it is 99% likely due to needing to be calibrated. Unfortunately this is a very common problem and comes up on this forum frequently. Only SDD can fix this.
Old Aug 9, 2020 | 02:47 PM
viper1996's Avatar
okay thanks where can I buy sdd? Might as well have the tool and do it myself if it's not too expensive but I have no clue
Old Aug 9, 2020 | 04:16 PM
MarkyUK's Avatar
Try disconnecting battery, doing a hard reset*, reconnecting and then holding the button of the back tilt for 10 seconds, that's what my Indy did and it worked a treat.
They said it was apparently caused by an FB (NOT FaceBook) passenger placing undue strain on the mechanism causing it to shut down, and no they didn't charge me
* If you don't know what a hard reset is after close to 600 posts there's no hope for you
Old Aug 9, 2020 | 05:17 PM
viper1996's Avatar
I hate doing hard resets but I'll give it a try and post my findings thanks
Old Aug 9, 2020 | 05:50 PM
MarkyUK's Avatar
No probs if you don't want to do a HR and are happy to pay for SDD work instead as the first attempt
My battery was actually changed so had the hard reset and was disconned for over 20 mins and a new type 019 fitted (also done free by my Indy).
steve12955
Mar 23, 2015 08:20 PM
2ndxk8
Jan 21, 2013 06:10 PM
azxj6
Dec 22, 2009 02:05 PM
Surfer-J
Jul 13, 2009 06:46 PM
Striker27
Mar 16, 2008 11:40 AM
