Supercharger oil change.
Old Feb 26, 2013 | 04:22 PM
muncher's Avatar
Default Supercharger oil change.
I recently changed the engine and trans oils/filters and want to change the supercharger oil. Has anyone done this? If yes could you advise how to do it and also the type and amount of oil to use.
Thanks guys.
Old Feb 26, 2013 | 05:04 PM
shaune's Avatar
Hello, the SC is Eaton's M112 model - same as used in Mustangs.
I believe you will need 2 bottles of SC fluid which can be purchased at GM dealer (part # below)
Here is a link to the procedure using the same Eaton SC but in a Mustang. Same procedures apply:
How To Change Supercharger Oil In 03-04 Cobras - Mustang Evolution
Old Feb 26, 2013 | 09:16 PM
Vector's Avatar
https://www.jaguarforums.com/forum/x...e-notes-57136/
Vector
Old Feb 27, 2013 | 03:55 PM
muncher's Avatar
Thanks for the info guys. Can i just double check one thing. I take it the oil level goes up to the drain plug. Cheers.
Old Feb 27, 2013 | 04:07 PM
shaune's Avatar
8oz is what the factory calls for so as long as you use two 4oz bottles of the fluid pictured above you will be ok. If it pours out before then just wait til it stops, and screw the filler cap back on.
Old Feb 27, 2013 | 05:07 PM
plums's Avatar
The M112 is something like 6.8 fluid ounces.
mrplow58
Jan 21, 2024 05:53 AM
duecedriver
Dec 25, 2015 11:47 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
AtholC
Sep 9, 2015 09:07 PM
