Suspected battery trouble
Old Dec 30, 2016 | 03:05 PM
wjpjazzy's Avatar
Default Suspected battery trouble
Just went outside to take a spin in the XKR and it doesn't start. I think it's the battery I don't keep it on a tender. My question is it ok to jump it with a battery box. My dealer is 75 miles away.
Old Dec 30, 2016 | 04:08 PM
jagtoes's Avatar
I would charge the battery with a 10-15 amp charger . Once charged have the battery check to make sure it is OK. Then start it and after using the car put a smart charger on it. After charging you should get around 12.6 Volts.
Old Jan 2, 2017 | 08:48 AM
1 of 19's Avatar
You will be allot happier with your XKR experience with a battery tender that is utilized.
Old Jan 2, 2017 | 09:53 PM
wjpjazzy's Avatar
I ordered a ctek Saturday.
Old Jan 5, 2017 | 10:16 AM
RedRider48's Avatar
Might have tried to start by depressing the brake pedal first, then, the start button?
It's been advised here in the past, this is the better start procedure......
Old Jan 5, 2017 | 10:34 AM
Stuart S's Avatar
Ken,
I'm not clear on what you just said but I think you have it backwards. Although the Owner's Handbook says to step on the brake pedal and then push the start button, based on my experience it is better to press the start button first - fires right up with just a tap of the brake pedal. Inadvertently stepping on the brake pedal multiple times (pumping the brakes) can make the car very hard to start and you have to really stand on the brake pedal to close to starter switch. You avoid that problem by pushing the start button first.
Stuart
Old Jan 5, 2017 | 11:26 AM
kj07xk's Avatar
Been following Stuart's method since I first read it, works much better than the Owner's Manual method.
Old Jan 5, 2017 | 11:34 AM
RedRider48's Avatar
Originally Posted by Stuart S
Ken,
Stuart
Stuart, and to others, I had it backwards. Thanks for clarifying.
In any event, perhaps the previous poster has a bad start ckt. in the brake system?
Old Jan 5, 2017 | 01:50 PM
Stuart S's Avatar
Ken,
No problem. Because we're human we make misteaks!
Stuart
Old Jan 5, 2017 | 02:01 PM
RedRider48's Avatar
Ken,
Stuart
...yeah, mestew!
Ha, Ha, Ha...
