Technology questions
Old Mar 11, 2015 | 06:28 PM
drbill's Avatar
Default Technology questions
1. Does the 2012 XKR have bluetooth option for the audio? In other words, can you play your tunes from iPhone wirelessly as the car came equipped?
2. Second question, is the GPS still C/D based and if so, is it upgradeable?
3. Is the technology suite (bluetooth, GPS, etc) better on the 2012 as compared to the 2010?
Thanks,
Bill
Old Mar 11, 2015 | 07:07 PM
ralphwg's Avatar
Answers:
1. No, you cannot play music via bluetooth, but you can plug in an ipod, thumbdrive, or mp3 player to play your own music
2. The GPS system is dvd based and you can update the discs for around $200 per update.
3. I don't know what you mean by this question. But the infotainment system is essentially the same as the 2010 version.
Old Mar 11, 2015 | 08:08 PM
BruceTheQuail's Avatar
Hi. The way to tell the difference is that the "old" system has a blue screen and the new one has a black screen. I had the black screen in my '12 XF but I don't know when it came into the XK range.
With the black screen system, it runs on a HDD. I found it dreadfully slow and irritating to use compared to the blue screen although it has less windows. But I was always hitting the wrong button when I was driving. Also it takes about a half minute to boot up when you start, so no reverse camera until you have already reversed out of your space, the music has a similar lag. The sat nav is just as slow as it was before but it is HDD based rather than DVD based.
You do get Bluetooth streaming on music but then the CD/DVD is one disk in dash with storage into (from memory 12) slots. That takes like about 5 minutes to upload. I didn't see the point, but then I am a pretty impatient guy, and anyway I use USB sticks for everything.
So all told it is more advanced, but not necessarily better. If I had a choice I'd had the HDD setup, only because it is newer, but I didn't see it as going backward when I went back to the blue one for the XKR.
Old Mar 12, 2015 | 12:20 PM
andys-GR's Avatar
If you want to stream music via blue tooth, I have a ViseeO Tune2air WMA1000 plugs into the i pod port works smoothly my samsung s5 connects both to ViseeO and streams Pandora and the Jaguar system for the phone. There's a bunch of threads on here about it.
FrickenJag
Jun 16, 2025 02:15 PM
redgear
Sep 18, 2015 10:05 AM
SeanU
Sep 18, 2015 08:09 AM
DustysSon
Sep 13, 2015 04:17 AM
Foosh
Sep 11, 2015 03:35 PM
