Is there a choice to display...
Old Jun 12, 2013 | 07:52 AM
Donzi's Avatar
Default Is there a choice to display...
anything else other than the animated analog clock on the drivers screen...?
Old Jun 12, 2013 | 10:57 AM
rscultho's Avatar
R u in the correct forum?
Old Jun 12, 2013 | 11:25 AM
Donzi's Avatar
Yes, I am. BTW I did buy the larger spioler you posted the link to, Thanks!
Old Jun 12, 2013 | 11:36 AM
rscultho's Avatar
My apologies...I have a leaper that appears when I press the home screen...and I rarely change it so I don't really know what can be displayed, but I don't remember an animated clock...
Old Jun 12, 2013 | 12:23 PM
JeremyB's Avatar
You have a choice of:
- 'Screensaver' Analog Clock
- 'Screensaver' "Leaper"
- an actual screen ie Nav or Audio.
From the main screen, go to 'Vehicle' Tab
Then 'Syst. Settings'.
That will give you the choice of the 2 'Screensavers', and a thumbnail of each. You can also enable/disable this screensaver, and adjust the timeout parameter.
I couldn't get a screenshot here from an Adobe version of the very comprehensive Owners Manual, but its all listed in there. May I suggest you download a copy (there are numerous links on this site) if you don't have a copy ??? I discovered all kinds of features I'd already paid for...
Jeremy
Old Jun 12, 2013 | 02:57 PM
Donzi's Avatar
No guys, not the nav screen...the drivers screen in the center of the dash behind the steering wheel. There is this annoying little analog clock there... above the odometer.
Sorry, should have been more clear in my first post.
Old Jun 12, 2013 | 04:35 PM
Hailers's Avatar
No.
Then again, you can disable one of your TPMS sensors and the display will show the outline of a vehicle with a faulty tire sensor or low pressure tire. humor, please
Old Jun 13, 2013 | 04:55 AM
rscultho's Avatar
Originally Posted by Hailers
No.
Actually, if one of the TPMS sensors is malfunctioning you get a big yellow Triangle there...
If sensors are working properly and the pressure is too low you get the sexy outline of the XK with the tire outlined in yellow and a message...
Old Jun 13, 2013 | 09:24 AM
Rahtok's Avatar
On mine, if you're using the Nav system you'll get turn directions there in place of the clock. Alternatively, if you flip the Tranny to S, you'll get big numbers there for what gear you're in -- a la rally car style.
Old Jun 13, 2013 | 10:02 AM
djgold's Avatar
I don't get directions in nav mode nor gears in "S" mode... only a clock... I imagine it's because I have 2007-2009. Must be new for 2010+ Damn...
Old Jun 14, 2013 | 11:12 AM
Hailers's Avatar
True enough about the large yellow triangle with a disconnected sensor. My bad. But then again it is another display other than a clock.
On my car I had a problem with the TPMS and the car display with the red tire going from one tire to the other was sort of *fixed* finally by gently pulling and pushing on the connectors on the TPMS module behind the auxillary junction box. Suspect a cold solder joint in either the plugs themselves or the jacks themselves in the module. A temp "fix" that usually lasts for a couple of months, then it's back to massaging the elect connectors on the TPMS monitor once more.
Old Jun 15, 2013 | 12:54 PM
jagxk2008's Avatar
go little further down and you can display
"all show quality"
Old Jun 15, 2013 | 01:38 PM
Donzi's Avatar
"all show quality"
Deleted.
Old Jun 16, 2013 | 06:27 AM
rscultho's Avatar
nt
Old Jun 16, 2013 | 06:50 AM
Donzi's Avatar
Yes, admitadly it was immature..
You missed alot more that has been deleted...
I did delete this one, but your quote is perpetuating it now.
He was NEVER trying to help, just wanted to start some $#it
Old Jun 16, 2013 | 10:19 AM
Bruce M.'s Avatar
The coolest image on the Nav screen in my 2010 XKR is the "R" on start-up. But for some reason I can't select that as a screen saver. So my default is a rather small leaper.
The only area in which my prior Jag, a 2004 XJR, tops this one. The leaper was much bigger and better executed, and against a Racing Green background...
Old Jun 16, 2013 | 11:36 AM
Lothar52's Avatar
Who knows... I try to stay away from the infotainment unit.... Ha!!! Just roll the windows down, put it in dynamic mode and listen to the engine
Wolfy
May 28, 2024 08:06 AM
GGabriel
Nov 22, 2018 03:53 AM
N3yyz_XJR
Sep 27, 2015 11:26 AM
Jaguar Forums Editor
Jaguar Press release
Sep 17, 2015 11:18 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
