View Poll Results: Add meth/water kit?
Yes
0%
No/not needed
100.00%
Voters: 1. You may not vote on this poll
Are these boost/hp #’s accurate?!
Old Oct 9, 2025 | 01:11 PM
Obtuse1's Avatar
Default Are these boost/hp #’s accurate?!
If I go to this from stock, do these numbers look correct? The car is a 2015 XKR.
Mina lower pulley,181.00 mm (reported?)
New custom griptek upper pulley👉🏻 decrease to 3.20 in = 81.28 mm (stock is 3.3” or 83mm?)
=Supercharger speed change vs stock,+22.800%
Estimated boost,≈11.05 psi (≈+2.05 psi)
Theoretical peak power,≈626.28 hp
Realistic expected power (VAP ecu tune) ~586–637 hp
Plus I’ve added new 3” fresh air intake w hi flow k&n
TB ported and polished
X pipe w center resonator delete up to 2.5” from 2 1/4 stock
S/C top intake polished
S/C ported and polished
upgraded charge cooler and pump
thoughts? Advice? Are the pulley sizes accurate? @everyone
Tra5.0sc
Apr 25, 2023 12:02 AM
VicVegas84
Dec 8, 2021 08:39 PM
AlexJag
Mar 14, 2018 09:01 PM
WaterDragon
Mar 14, 2014 06:11 PM
WaterDragon
67
Jul 5, 2013 09:49 AM
