Tire Pressure Monitor info, MUST READ!!!
Old Jan 11, 2009 | 05:22 PM
Real_Tech's Avatar
Default Tire Pressure Monitor info, MUST READ!!!
New SSM from Jaguar, "After reviewing tire pressure monitors returned for warranty replacement we have found that installation of metal valve caps has caused breakage of the valve stems and will not be covered under warranty. Corossion between the metal cap and the aluminum stem is causing seizing. Technicians are advised to remove any metal valve caps and replace with gray plastic caps installed at factory."
If you have metal caps and they don't want to come off try a little heat from a micro sized butane torch being careful of the wheel and damage to the valve stem seal. It doesn't take much heat and has been working for me. I've replaced several tire pressure monitors for this problem.
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
carcycle
Sep 7, 2015 10:22 AM
Sprayall
Sep 3, 2015 07:49 PM
