Tire pressure sensors
Old Dec 27, 2020 | 09:25 AM
jbmi's Avatar
Default Tire pressure sensors
Need to replace my 10 year old sensors, been giving me false alerts. Dealership says batteries wear out about 10 year old. Do Jag's use a different sensor than American models ?
Can I go to my local tire store and get new ones or would I need special order ?
Spring is coming and I want to take care of this.
Old Dec 27, 2020 | 10:02 AM
panthera999's Avatar
Just replaced one on my '07 XK (I chose to do them one at a time as they wear out). Yes, typically the batteries are good for 8-10 years. Any tire shop can do it. Prices each including install vary from $60 to $120 In the US. You need to get 315Mhz units. Best to do it all when they start to fail, or if it's been 10 years and you happen to be replacing tires. Shops will claim they need to "Program" them, which is not true in most cases. See below.
There are a lot of brands, but as always, use a name brand from a reliable parts house. I got a high-quality Schrader (OEM, I believe) brand from RockAuto for $42 and self installed, since I have access to a tire machine. Took 15 min to pop the bead and replace the unit.
Not clear to me whether pre-programmed units can be used in the XK, since I have SDD and used its TPMS registration program. Perhaps others can comment on whether the XK will accept pre-programmed units that don't require registration.
On my BMW (same era) I used pre-programmed units that did not require registration on the car (sometimes the installers call this "programming"). The BMW just sensed them and worked.
Failure is a normal maintenance item.
Best,
Panthera
Old Dec 27, 2020 | 10:53 AM
jons's Avatar
my XK works fine with normal aftermarket TPM sensors in the wheels, i forget the brand. they were programmed at the tire shop i bought my wheels through. the default frequency on the module was correct for north american vehicles however the sensor had to be told which wheel it was on -- i guess they either cannot relearn, or they don't speak precisely the same protocol as the onboard module in terms of learning that. the tech plugged each sensor into his TPMS tool where he could change/confirm the frequency, and set which wheel each was for. i observed the entire process. they actually got it wrong the first time around and i had to drive back.
Old Dec 27, 2020 | 11:04 AM
bocatrip's Avatar
Not meaning to sidetrack.....At what pressure does the sensor kick in to signal a dash alert? I have 19s with 36lbs in rear and 33 in fronts. PS... I'm driving with the original sensors from 2010.
Old Dec 27, 2020 | 11:08 AM
Cee Jay's Avatar
What are they......
Siemens 5007?
Now I have to go look...
"Siemens VDO 53004"
Old Dec 27, 2020 | 11:09 AM
Cee Jay's Avatar
I bought four new ones last year, hoping to straighten out my consistent TPMS ERROR. But after new sensors, initiators, module and receiver, I STILL have the FAIL.
Old Dec 27, 2020 | 11:14 AM
Bill Mack's Avatar
Are those the Jaguar or tire manufacturer recommended pressures? Jaguar says my 2007 should be inflated to 30 front, 33 rear.
Old Dec 27, 2020 | 11:35 AM
Cee Jay's Avatar
Look at the door jamb inside the driver door. Your inflation pressures are on a sticker. Manuals and internet be damned, go by the sticker.
Old Dec 27, 2020 | 11:49 AM
Stuart S's Avatar
For just about everything you need to know about your TPMS sensors and the entire system, this old thread from 2013 is worth reading from the beginning. There's good advice as to which sensors to buy, what to be wary of, and where to buy them.
https://www.jaguarforums.com/forum/x...ensors-107293/
New sensors need no programming. A short drive is all it takes for them to work - 10 minutes above 18 mph. It's amazing what you can learn when you
Anyone who charges you to program them is a thief!
__________________
I still have the original TPMS sensors and they're still working properly after more than 12 years. I hope I didn't just give myself the Kiss of Death!
Old Dec 27, 2020 | 12:23 PM
bocatrip's Avatar
Not certain, but you might very well be correct. I believe I have been used to keeping my tires 2-3 lbs over the recommended pressures to avoid constantly checking the pressures. I'd rather be a few over than under with the horrific friction from hot road temperatures here.
Old Dec 27, 2020 | 12:40 PM
MarkyUK's Avatar
US spec are 315 MhZ
UK are 433 MhZ
I bought my UK spec 5 x Jag OEM of ebay for £15 each, got a local tyre place with a wireless tool to check and they were all at 95%
Fitted them 4 of em to my Vulcans with winter rubber and no issues or warnings to report
Old Dec 27, 2020 | 12:49 PM
Bill Mack's Avatar
Originally Posted by MarkyUK
US spec are 315 MhZ
UK are 433 MhZ
It's interesting that the frequency is different between the countries. I guess it's because each country has it owns regulatory authority in charge of assigning portions of the electromagnetic spectrum for specific uses(?).
Old Dec 27, 2020 | 01:00 PM
Cee Jay's Avatar
My 2010 XKR. Yours may differ;
Old Dec 27, 2020 | 02:53 PM
sov211's Avatar
This is interesting - your decal is for the Canadian cars!
Old Dec 27, 2020 | 03:43 PM
Cee Jay's Avatar
Eh? Well, by golly, I guess you're right there, Sov.
It's hard to use an accent on a keyboard.
Old Dec 27, 2020 | 03:46 PM
MarkyUK's Avatar
Sure is, maybe CJ's defected?
Old Dec 27, 2020 | 03:48 PM
Cee Jay's Avatar
It was sold New at Park Place Jaguar, Dallas Texas. I got it CPO from Park Place Jaguar, Dallas Texas.
If it did, I don't know how.
Old Dec 28, 2020 | 10:47 AM
kj07xk's Avatar
That’s for 19” wheels. The 20’s run 3 lbs higher.
Found that out after putting 20’s on my ‘07 that came with 19’s, and it felt ‘mushy’.
Old Jan 4, 2021 | 07:57 PM
Feffman's Avatar
Cold weather and my tire sensors are suddenly possessed.
Old Jan 11, 2021 | 11:59 AM
Stuart S's Avatar
FYI ...
