Touch screen jumping & rolling
Old Dec 14, 2018 | 01:59 PM
pwpacp's Avatar
I've never had one apart but, if it is a PC board, be sure to check for hairline cracks as well.
Be sure to keep us up on what you find.
Old Jan 1, 2019 | 05:42 PM
digband's Avatar
Originally Posted by necpuglisi
I'm in coastal N.C with closest dealer being 3 hours away in S.C .Had dealer run diagnostics for about $165 gave two steps to rectify -Re-program Screen if that doesn't work replace screen for a total cost of $5,000. Next trip was to N.J. spent $165 for Diagnostics and was correctly told it was the Bluetooth Module $1,400 to replace. Bought a used one on E-bay for $145 removed the battery cover the 4 screws and 3 plugs on module and replaced with E-Bay purchase 6W83-10D893-AG .It's located just under the Nav CD holder to the right of the battery. Problem fixed.
Hope this info. helps
Thanks for posting about this fix - a couple questions: Can you explain the issue you were having on the touch screen display? Was it scrambled like the photo I posted above, or did it just stop displaying anything at all (go black), logo appeared only etc.? As far as reprogramming the touch screen display, did they say this was something that could be done via the entertainment system interface, or does it require some kind of device to be hooked up (i.e. has to be done in a shop/with special tools)? Did they provide a diagnostic code that indicated the Bluetooth system failure? What year is your XK? Thanks!
Old Jan 13, 2019 | 07:59 AM
necpuglisi's Avatar
Default Touch Screen Only flashing Jaguar logo
Sorry for delay Her's S.C. dealers notes "71054 inspected and checked for fault codes using SDD. inspected and found multiple fault lost communication fault codes. Recommendations were made to perform touch screen module software updates.Client declined to perform software update at this time estimates provided." I did buy a touch screen on ebay (returned to seller) Removed center bezel 6 torx bolts, slid entire center out replaced screen (easy) n it did the same flashing Jaguar logo on my 2008 XK. S.C dealer re software update was $370 Plus Tax, Replace screen was $4,535 Plus tax. I'd say cheapest way is replace screen, you could find on E-bay and or have software update.
Good luck
Old Mar 30, 2019 | 06:11 PM
digband's Avatar
UPDATE on my haywire TSD: I bought an optical loopback and looped out every module in the trunk next to the battery to see if was the Bluetooth module or Nav or something else, and no luck, still haywire - I even pulled the center dash module and made sure all the wires in the back were connected OK (getting the wood trim off was nerve-wracking!). I guess I conclude the issue is the TSD itself.
Question: see photo below - while I was in the trunk looping out the modules, I noticed a loose connector that wasn't plugged in to anything, which doesn't seem right - anyone know if/where this should be connected? Maybe you can take a look in your trunk and send a photo of where it ought to be plugged up? Thanks for any help on this.
Old Mar 30, 2019 | 09:07 PM
pwpacp's Avatar
As others will probably tell you, don't worry about that connector as it is only for use when the vehicles was being intially shipped and goes to nothing now.
Old Apr 7, 2019 | 10:56 AM
digband's Avatar
Reporting back on this thread - I was able to acquire a whole new TSD and am ecstatic to declare it is working perfectly. The troubleshooting was a good learning experience, but turns out it was just the damn screen unit itself. No more static, squiggling and blank screens. Thanks to all on the thread who gave advice - the TSB that shows how to get the middle console unit out of the dash was especially clutch.
Poet
Feb 7, 2025 02:18 PM
MrWhite
19
Jun 14, 2022 07:49 PM
Jagzzz
Aug 8, 2021 02:45 PM
X308XJR
May 20, 2019 06:50 PM
caldoofy
Sep 28, 2015 08:43 PM
