Touchscreen issue
Old Apr 5, 2024 | 02:30 AM
Square63's Avatar
Default Touchscreen issue
Guy’s
I recently had to jump start my beloved 07 x150 XKR and since replacing my old battery with a new Bosch one I cannot get my touchscreen to work ? I have looked at fuses in all 3 boxes and all are fine c, can anyone suggest a solution before I have to go to my local jag dealer and get ripped off by their exuberant ridiculous prices, here’s hoping regards to all jag fans Ali
Old Apr 5, 2024 | 03:43 AM
RichardS's Avatar
It would be worth checking the relay diagram to see if there is a relay involved which can also be checked.
Do you have an ODB scan tool which might provide some clues and enable you to clear any fault codes?
Did you leave the battery disconnected when you changed the battery or did you use a spare battery to maintain the 12V supply? Assuming that you fully disconnected the battery, it might be worth disconnecting both terminal connectors again and holding the +ve and -ve cables together for 30 seconds to try and reset the electronics. You will then need to reset the windows as detailed in the Owners Manual.
Richard
Old Apr 5, 2024 | 07:18 AM
Square63's Avatar
Cheers Richard, I will check relay diagram , much appreciated mate Ali
Old Apr 5, 2024 | 09:10 AM
Cee Jay's Avatar
You say you replaced your battery....... Dollars to Donuts that your new battery isn't fully charged. That's the main cause of what you say the problem is right now.
Old Apr 8, 2024 | 03:28 PM
Howell's Avatar
This is a long shot, but just push the power on button without starting the car, let the aux stuff come up, in my XKR, that sometimes will wake up the system, and then when you start the car, the systems all come up, particularly the display functions, Good luck
Old Apr 9, 2024 | 04:29 PM
wsn03's Avatar
I have the same issue. My new battery is now fully charged. Tomorrow im going to disconnect it, put the terminals together for 30 seconds, then reconnect (i will consult my research to double check this).
Starting to run out of ideas, would like to understand how to check the relay though, will re-run diagnostics
Old Apr 9, 2024 | 06:59 PM
jahummer's Avatar
A much simpler explanation’s the TSD’s failed. It’s becoming more common with age.
Old Apr 9, 2024 | 07:05 PM
wymjym's Avatar
If it has failed. would the Tesla style be a viable replacement? Or are there other components that would also need to be replaced?
wj
Old Apr 9, 2024 | 07:23 PM
jahummer's Avatar
@wymjym yes any compatible screen would be a suitable solution.
The screen on my X150 worked perfectly. Then the car went into storage for nearly a year and the battery flat. Screen no longer worked. Replaced with a new and no further issues. As electronics age, components, especially capacitors become sensitive to lack of use.
Old Apr 9, 2024 | 07:32 PM
wsn03's Avatar
what was your new replacement- a standard brand new oem? Tesla style big screen? Or a 2nd hand oem?
chater210
May 28, 2024 08:07 PM
SpartanBadger
Nov 1, 2021 03:49 AM
Busyb187
Jun 1, 2018 10:58 AM
lspencer534
Jan 3, 2015 03:33 AM
04JagXtype
Oct 3, 2013 05:00 PM
