Tpms problems
I have a 2011 xk that has intermittent tpms problems. I had all 4 sensors replaced recently.
I would like to clean the tpms receivers, where are they located?
thanks.
thanks.
You would gain the most info by searching this forum for "TPMS" as there are numerous threads about the ongoing problems associated with it.
Receiver on the RSJB, initiators in the wheel wells behind splash shields. Much more needs to be checked, however.
If your sensors are all sending values (checked using the handheld readers a tire shop uses), then the receivers or module is bad. I replaced the module and sensors and that didn't fix it, so I disabled the entire system using SSD. An autologic scanner can do it as well.
I've got a pretty long thread about my experience.
https://www.jaguarforums.com/forum/x...r-data-221649/
https://www.jaguarforums.com/forum/x...system-256345/
I had not driven car for 3 months due to snow and cold weather.
Car would not crank, replaced battery and now my tpms problems seem to have disappeared.
Battery was 5 1/2 years old.
That’s what we keep telling people… some choose denial.
We also tell others that battery age has little to do with battery health. They ignore the advice then keep it on a maintainer citing “see, it’s fine”. Go figure.
There is a difference between trickles and maintainers. Trickles run the risk of overcharging (thus destroying) the battery. Maintainers monitor the battery and shut off when there is an overcharging risk.
Here in Florida Melbourne..
an INCREDIBLE collection..
American Muscle Car Museum..
Mind blowing..
All on chargers of some sort.
over 200 cars..
google it,,,its great!!!
I went to test drive a new C7 Corvette several years ago, all four of the floor models had dead batteries. They all had maintainers connected to the car, but all the cords were tucked away inside the car. Needless to say there were no test drives that day. I returned a week later and all four were properly connected and startable.
philipp.j.s.
Dec 28, 2025 04:23 AM
