TPMS-Tire Pressure Monitoring Sensors
Old Dec 25, 2019 | 10:44 AM
  #61
chazaroo's Avatar
Am I correct that if the problem is the module under the front passenger seat, then you will get a Tire Pressure System fault not the round robin check tire pressure fault going from tire to tire?
Old Dec 25, 2019 | 11:16 AM
  #62
Cee Jay's Avatar
What module under the seat? The actual "TPMS MODULE" is behind the rear seat. In a convertible, it is also behind the Roll Over Protection hoops.
Maybe the TPMS Receiver is under that seat??? I'd hope so, as that's the lost possible thing to fix MY TPMS faults. I really don't want to remove the whole debacle behind the seats again.
Old Dec 25, 2019 | 12:34 PM
  #63
chazaroo's Avatar
I found that in an article in here somewhere. I guess it depends on which model year you have too. I also found mention of it in the rear. Now I'm not sure where the thing is.?
Old Dec 25, 2019 | 12:47 PM
  #64
Stuart S's Avatar
Cee Jay is right. The TPMS Module is behind the rear seat. From the 5.0L Workshop Manual, #11:
Old Dec 25, 2019 | 01:14 PM
  #65
Cee Jay's Avatar
I just found the TPMS Receiver location..... super-easy. It's directly on top of the RSJB. Only need to pull out the rear seat center divider cover thing.
Old Dec 26, 2019 | 09:58 AM
  #66
chazaroo's Avatar
So, if the module is the problem will you receive a "TPMS System fault" instead of the "Check tire pressure" warning?
Old Dec 26, 2019 | 10:48 AM
  #67
Stuart S's Avatar
That appears to be correct.
Old Dec 26, 2019 | 11:14 AM
  #68
Cee Jay's Avatar
Yeah, but I've had TPMS FAULT even after I replaced the Module. AND after I reprogrammed both the old AND new modules. All my tire sensors are brand new, along with all four initiators. Other than the wiring, the only thing left for me is the Receiver.
Old Jan 2, 2020 | 12:45 PM
  #69
110reef's Avatar
OK, so I checked the air pressure and it was way high. Like 45 psi. Stupid tire shop. So I dropped the pressure to what it was supposed to be. Drove around for a while. Still got the intermittent "Check all Tyre Pressures" warning. So I let all the tire pressures down to <15 psi and filled them back up. Still get the intermittent "Check all Tyre Pressures" warning.
I got the sensors off the internet, and they are 350 Hz. I no longer get the individual tire low pressure warning.
Still wondering what to do. Would disconnecting the battery and touching the leads together help?
Old Jan 2, 2020 | 01:27 PM
  #70
Boga's Avatar
I think you mean the frequency is 315 mhz.
On my 07 XK, I had a slow leak in one tire.
The independent tire shop I visited showed me that the leak was around the securing nut, not the shrader valve.
He would not touch it, fearing it would break. He recommended I go directly to a Jaguar dealer, saying that I could use only Jaguar sensors.
There is a lot of discussion about which sensors work and which do not. I do not know the answer to that.
In any case, I went to the Jaquar dealer who replaced the sensor for $170 plus $100 labor.
Happy but not happy,
Bob
Old Jan 2, 2020 | 04:09 PM
  #71
110reef's Avatar
Sorry - 315 Hz is correct.
Yeah, so $270 per tire, or over $1000 for them all. No thanks. I'll live with the warning first.
Old May 29, 2020 | 04:30 PM
  #72
Cee Jay's Avatar
Sort of an update on my particular situation;
I changed out all the components over winter, and I still had the TPMS fault on the dash.
Now that I've been driving a lot more, I noticed that the FAULT went away, and only sometimes do I get the flashing Tire Symbol on the dash.
PROGRESS!
Since all new wheel sensors, guess I'll try the Over-Inflate trick.
At least I'm getting closer!
Old May 29, 2020 | 07:17 PM
  #73
ralphwg's Avatar
I used to get the fault icon off and on several times a month. Your posting reminds methat I haven't seen the fault icon now for several months without having done anything to the system (hope I haven't jinxed it).
Old May 30, 2020 | 11:03 AM
  #74
carealtor's Avatar
My follow up: My Jaguar dealer shop told me the codes indicated that the TPMS module was bad. $1000 later, the problem has completely gone away. As far as I know, I still have the original, now 8 year old, senders in the wheels.
Old May 30, 2020 | 11:16 AM
  #75
Cee Jay's Avatar
I got my new TPMS module for $125 bucks or something like that. It was easy to replace, just behind the rear seats. I hope your $1000 included a lot of troubleshooting. Course, since "works", it'd be worth it regardless.
Old Jun 1, 2020 | 03:05 PM
  #76
007XKR's Avatar
Regarding Jaguar only TPMS... I had a screw removed from a tire, and the shop broke the TPMS while trying to inflate it. They installed a rubber-stemmed aftermarket TPMS, which was what they had on hand. The car displayed an alarm after that, but I wasn't concerned because I was taking it to the dealership for another issue the following day anyway. The dealer claimed that the TPMS generally needed to be Jaguar branded. I informed him that the original one was labelled 'Ford'. They checked it out and said that the tire shop had set it to the wrong frequency, and everything was now fine. Moral of the story: They do not need to be Jaguar-branded TPMS, at least not on an 07 XKR.
Old Jun 1, 2020 | 03:31 PM
  #77
Cee Jay's Avatar
A shop cannot "set" a frequency. The sensors are either 'Right' or 'Wrong'. There would be ZERO reason for a shop in Wyoming, USA to have a European TPMS sensor with 433 MHz when the US uses 315 MHz exclusively. The dealer is lying to you about two things at least.
Your car doesn't need anything SET. It will learn the TPMS sensors while driving within 60 miles.
Besides, the "CORRECT" TPMS sensors are Siemens brand.
Old Jun 1, 2020 | 03:45 PM
  #78
007XKR's Avatar
My trust level in dealerships is low, always has been. The issue did go away after they looked at it, and they did not charge me for that. I can't tell you exactly what they did. My assumption is that they try to scare you into buying branded parts, and also try to dissuade you from using indy shops. I thought that the alarm should go away on its own after putting a few miles on it, as the manual states, which it didn't. Those woes aside, my TPMS does not need to have Jaguar stamped on it.
Old Jun 2, 2020 | 09:40 AM
  #79
Boga's Avatar
My understanding is that the in tire sensors are manufactured to be able to transmit either 315 or 433 mhz.
The programming sets the frequency to use.
If purchased from Jaguar, it will be already programmed.
If purchased elsewhere, who knows.
These things need to be programmed before use, then after that, the car relearns what ever it needs during a short 20 mile drive.
Bob
Old Jun 2, 2020 | 11:48 AM
  #80
Cee Jay's Avatar
The programming sets the frequency to use.............................
You CAN buy a 2-in-1 sensor for a premium price, but WHY? The entire world sans Europe uses 315 MHz, which uses 433 MHz. It would make zero sense to sell 433 MHz to the entire world if it is only a very small market.
No tire shop will stock the more expensive and useless dual-mode sensors, and certainly not stock the ones used in a different country.
